Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 01-07-2009, 01:21 AM
bismic's Avatar
bismic bismic is offline
bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold
Draining water from the primary fuel filter (HFCM)
This post will present the procedure for draining water from the primary fuel filter (Horizontal Fuel Conditioning Module / HFCM / fuel pump).
(note - link in tech folder is broken so I have put this together)
Before posting the links to the procedure, there are several points worth making:
1. Get a large diameter drain pan to collect the drained fuel. The larger the better. I use my 20 inch diameter oil drain pan.
2. The factory drain plug in the HFCM is a 6mm hex drive brass plug (removed with an Allen wrench). It is prone to stripping AND it allows fuel to drain along the frame rail, creates a mess, and has been known to soak the person doing the job. Also, if you keep this factory plug, be sure not to over tighten it!
3. An upgraded drain plug exists (and is highly recommended) that allows a "finger tight" installation that eliminates the issue of stripping the brass plug. This plug, if necessary, can also be removed with a 6mm Allen wrench or pliers since the plug is not "flush mounted" like the OEM plug is. It is designed with an "extension" so that it does not have to be completely removed from the HFCM like the OEM plug. This extension also causes the fuel to "wick" along the plug and away from the frame rail. This enables the flow to be directed into a container and practically eliminates the mess.
Improved Fuel Filter (HFCM) drain plug:
http://www.forddoctorsdts.com/articles/article-05-19.php
http://www.itpdiesel.com/store.php/products/HFCM_DrainPlug
Optional fuel filter drain plug Ford #6E7Z-9C082-A or International #2589259C91
4. Diesel fuel will eventually swell rubber products. Coating the drain plug o-ring with oil before re-installing will help some to preserve its life, but you should keep a spare on hand because you most likely will need it at some point (I have 42k and I just had to replace mine).
5. The WATER IN FUEL (WIF) light will come on when approximately 0.2 pints (100 cc) of water accumulates in the module. Ford recommends draining the water from the HFCM monthly (IIRC) OR when the WIF light comes on. I do it every oil change. If you ever get the WIF light, drain the HFCM immediately.
6. If you keep the original drain plug, one recommendation I have read (primarily for 4x4's) was to get an 8 inch funnel and place it between front drive shaft and frame rail. Aim it into a catch pan and you won’t end up smelling like fuel for the next two days. You can also use a sheet of aluminum foil - you may have to play with the length and shape, but it should also help direct the flow of fuel into a large container. I personally love the modified drain plug. It drains perfectly into my container.
7. Last, after I have drained the HFCM and re-installed the plug, I cycle the ignition before starting: 1 cycle of (ignition on for 3 sec, ignition off for 15 sec), then ignition off for 3 seconds and START. This is an abbreviated version of the procedure after a filter change. It is most likely not required, but I do it anyway - personal preference.
Now the links to the actual procedure (they also include filter change procedures):
http://www.dan.prxy.org/Truck/Owners_manual/Service_Points/HFCM/HFCM.html
http://www.dieselfiltersonline.com/D...ence-Guide.pdf
Please share what has worked for you.
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20; DieselSite Coolant Filter; High Idle Mod; HFCM Plug; Zoodad/Air Fury grill; Accufab Elbow; RACCCV6000 filter; JimmiJammers; Ravelco; SynchroMax in Transfer Case; Fumoto Valve; Harpooned fuel tank; Line-X; CPOhighway Products tool box; tracrac; Fox Weatherboots; Wet Okole Seat Covers; Stanadyne Performance & B2 for lubricity; PIE adapter (thanks Sarge); PIAA 24" wiper blades; updated EGR valve; BriteBox; Re-flashed; Fuel Pressure gauge; DashDaq on deck
  #2 (permalink)
Old 01-07-2009, 01:32 AM
duffman77's Avatar
duffman77 duffman77 is offline
duffman77 is starting off with a positive reputation.
I have seen many on here claim that the hex plug is a real beeatch to work with but my 6mm hex tool fits like a glove and I see no need to upgrade.
Contrary to popular opinion, fuel is not supose to just keep flowing out, the amount that comes out is just the volume of the HFCM assembly, but its a good idea to do this when the tank is low. I use a 750g supermarket plastic honey container and hold it up to the plug. I wear dishwashing rubber gloves while doing it and have never gotton diesel on myself and very little hits the ground even on a filter change, one of the benefits of 2wd .
I myself use a fuel conditioner religiously (it controls water) and both times I have had the plug out there has been no water so I dont worry about this anymore myself.
  #3 (permalink)
Old 01-07-2009, 12:56 PM
jomac11's Avatar
jomac11 jomac11 is offline
jomac11 is starting off with a positive reputation.
I have only done mine once (almost to 30k), but I had zero problems. I used a 6mm allen wreck and opened up the plug. I took an old apple juice bottle (plastic) that was rectangular in shape, probably 3"x6", and it fit perfectly between the driveshaft and the framerail. I got some diesel on my hands, but I like the idea of kitchen gloves, so I think I will give that a whirl on my next one...
__________________
07 F-250 XLT SuperCab, 6.0LPSD, Torqueshift
Mods: 20% Tint, EGR in-channel window visors, Putco Chrome door handles, gas cap, and tailgate handle, Huskyliner floormats, B&W Turnover Ball, Rhino Liner, 4" magnaflow stainless turbo back, 20" KMC XD Hoss and 325/50/20 Mickey Thompson ATZ
  #4 (permalink)
Old 01-07-2009, 01:55 PM
bismic's Avatar
The issues with mess while draining the HFCM seem to be primarily with the 4x4 models:
From FDDTS web site:
"October 21, 2005 Having troubles draining your fuel water separator on your 2003 or newer Ford Super Duty truck? You are not alone and in fact, many technicians and owners that perform their own maintenance report that the 6 millimeter hex plug frequently strips out due to the soft metal that they are made from. Unfortunately once this happens most attempts to remove it fail. But when the plug does perform as designed fuel usually drains from the HFCM (Horizontal Fuel Conditioning Module) it spills onto the front drive shaft of 4X4 models and drips uncontrollably onto the ground and usually the person removing the plug."
__________________
Mark
  #5 (permalink)
Old 01-07-2009, 03:31 PM
D8chumley's Avatar
D8chumley D8chumley is offline
Resident Smarta$$
2004 Ford F-250
D8chumley is gaining momentum as a positive member of FTE. D8chumley is gaining momentum as a positive member of FTE.
What if you LIKE smelling like diesel fuel for a few days? JKStill can't rep ya, but I didn't forget! Haven't had WIF light yet but just updated plug anyways.
__________________
'04 F250 KingRanch CC FX4 6.0 swb "BIG D"
Tim
GO FLYERS!
Originally Posted by hubler13f
When congress refuses to provide soldiers with the equipment to complete the mission. S.T.E.A.L. Sudden Transfer Of Equipment to an Alternate Location
  #6 (permalink)
Old 01-07-2009, 04:01 PM
doubledee715's Avatar
doubledee715 doubledee715 is offline
doubledee715 is starting off with a positive reputation.
Doing this today for the first time. Post back with how it goes.
__________________
David, 2003 f250 centennial edition, afe, arp, itp, innovative tunes, 4" straight pipe, dieselsite coolant filter, blocked off egr cooler, quadzilla commander w/pillar mount(pos), 4.5" lift, f350 rear blocks, bilstein 5100's, 20/9 kmc hoss, 35/12.5 toyo mt, tinted tail lights, 35% front window tint..
  #7 (permalink)
Old 01-07-2009, 04:23 PM
flashart24's Avatar
flashart24 flashart24 is offline
flashart24 is starting off with a positive reputation.
I have had to do this twice and soon after that I narrowed down the service station causing the problem. My plug also stripped out so now I am just more careful but thanks for the new plug upgrade info. As far as the diesel on my hand it normally gets transferred to my beer huggie after putting the plug back in .
  #8 (permalink)
Old 01-07-2009, 05:56 PM
you know, I hear a lot problems about fuel in other states but in the over a year I've been on the forums I can't remember off the top of my head of anyone from california that had issues with bad fuel. Because california has more strict standards maybe?
__________________
  #9 (permalink)
Old 01-07-2009, 06:08 PM
DCSpecial's Avatar
DCSpecial DCSpecial is offline
DCSpecial has a great reputation on FTE. DCSpecial has a great reputation on FTE. DCSpecial has a great reputation on FTE. DCSpecial has a great reputation on FTE.
What has worked for me:
6.0 Fuel Filter Change
That's on a 2wd, on a 4x4 I just use a 6mm hex key since the ratchet doesn't fit.
I've never gotten a "diesel bath" as some people have reported.
__________________
DC
2001 F-350 PSD 4x4 Hell Raiser, Heavily Modified
2007 F-350 PSD 4x4 Work Horse, Moderately Modified.
Other 2wd PSDs: 99 F-450, 00 F-450, 01 F-350, 02 F-350, 02 F-550, 04 F-450, 06 F-450
  #10 (permalink)
Old 01-07-2009, 06:50 PM
Alright I'm literally outside and just did this. It seemed like nothing but diesel was coming out from the beginning. I let out about 3 secs worth then smelt it and it smelled like diesel. Normal? Also, no diesel bath here...instead of completely taking the plug out I kept it in just let the water/diesel drain until the stream got a little lighter. First time doing this and I don't see how anybody could get a "diesel bath" doing this. lol
__________________
  #11 (permalink)
Old 01-07-2009, 08:07 PM
bismic's Avatar
Great write-up (in your link) DCSpecial. Thanks. You definitely have more room w/ a 2-wheel drive than the 4x4. I have pretty much always had the "improved" drain plug and am very happy with it. However, the o-ring did swell on me a few weeks ago and it was hard to take it out - even with pliers. I guess I can see how the OEM plug could strip out if it got as hard to remove as my "improved" plug. I took the o-ring off of the OEM plug and it works great now / again.
As to the diesel bath - sounds like that may be somewhat exaggerated, but again I haven't done the job with the OEM plug - only going by what I have read in a number of posts in the past.
The responses have been great - thanks to all for improving the usefulness of this thread.
__________________
Mark
  #12 (permalink)
Old 03-06-2009, 05:52 PM
wedge88 wedge88 is offline
wedge88 is starting off with a positive reputation.
How often is this recommended? I would assume at each oil change it is a good idea to change the fuel filters and drain. Any other time necessary if the light does not come on. Please pardon my ignorance but I am purchasing my first diesel and upgrading from the F-150 x 4 so I have been reading a ton.
__________________
2006 F-250 Superduty Crew Cab, Lariat, FX4, Chrome Package, Line-X, Ford 6" S/S Step Bars, 6.0L Powerstroke, BFG 285/65/20 35" x 12"
2008 Ford Edge SEL AWD
2006 F-150 Screw FX4 150"WB - Sold
  #13 (permalink)
Old 07-06-2009, 09:44 PM
Jayybird Jayybird is offline
Jayybird is starting off with a positive reputation.
Ok guys, i just bought my first diesel, 05 4x4 PSD. Unless I am going crazy, the bottom frame mounted fuel filter is not horizontal. Its veritical, different from what I am seeing in Bismic's link,
http://www.dan.prxy.org/Truck/Owners...HFCM/HFCM.html
I assume it would be the exact same procedure for me or is there something i am missing? THanks for the help
  #14 (permalink)
Old 07-06-2009, 09:53 PM
bismic's Avatar
Look it over real good for a brand name. You must have an aftermarket filter. If the filter is aftermarket, then you have an aftermarket fuel pump also. Can you take a picture and post it?
__________________
Mark
  #15 (permalink)
Old 07-19-2009, 10:14 PM
Hey guys,
I attempted to change my fuel filters today (05 PSD). My understanding, per the above directions, for the primary/chasis fuel filter is to remove the drain plug on the HFCM to let the diesel in the housing completely drain before changing the filter. I started this and set up a funnel to catch the fuel and drain in my basin (no big deal). It seemed to take a while to drain, the fuel just kept trickling. So, to keep from making a mess i was patient and just let the fuel continue trickling out and went ahead and cleaned my airfilter. Well about a 1 hr later, the fuel was still trickling out of the HFCM plug and I had about 2.5 gallons of diesel fuel in my basin. Again, how much fuel should drain out of this thing? I thought it would just drain the volume of the housing?? And once completely drained you could change the filter. Any input?
Tags
2007 , 60 , drain , f250 , f350 , f550 , filter , ford , fuel , hfcm , procedure , separator , seperator , superduty , water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
