Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 01-06-2009, 10:04 PM
daggerfalls daggerfalls is offline
daggerfalls is starting off with a positive reputation.
352 to 390 conversion
I want to replace my very tired 352 with a rebuilt 390. I also need to replace the clutch. with a complete clutch kit. I have a 66 F100. What considerations regarding clutch, transmission, and pilot bearing do I need to consider? thanks ahead of time
  #2 (permalink)
Old 01-07-2009, 12:55 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a good reputation on FTE. Kemicalburns has a good reputation on FTE.
should be a strait swap. how do you use this vehicle? that would determine the type of clutch to run. have the proper flywheel for the 390 etc..
__________________
94 XLT 5.8/E4OD
6"ProComp Stage II 35x12.5x15 BFG MT's ,
4.88 gears f/r
JBA shorty, Custom Y pipe,3" exhaust
Warn HS9500I
installing soon: Edelbrock efi truck intake, aussie locker front/rear
http://www.supermotors.org/registry/...il.php?id=4158
  #3 (permalink)
Old 01-07-2009, 06:33 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
DIdn't you ask this in the FE forum too? Either that, or someone else asked the exact same question
Should be a straight swap.
The pilot bearing, I'd make sure was the same before installing the motor.
Otherwise, yeah, same thing.
What I'd do is use the flywheel from the 352, and get the clutch for the correct year 352. Otherwise, there might be a size difference, but nothing huge enough to care about.
Was the 390 rebuilt already? If you can, get the 390 rebuilt and balanced, WITH the 352 flywheel on it. Less vibrations that way.
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #4 (permalink)
Old 01-08-2009, 01:15 PM
i agree with Krewat, also if the motor is getting rebuilt do some head work and upgrade the cam. the 390 will really wake up from these small changes and be a runner for sure. also run long tube headers on that motor.
__________________
94 XLT 5.8/E4OD
4.88 gears f/r
Warn HS9500I
  #5 (permalink)
Old 01-08-2009, 01:33 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
The 1965/67 F100/350 352 flywheel is the same as the 1968/76 F100/350 360 flywheel (C5AZ6375K) and uses an 11" clutch on a bolt circle diameter of 12 3/8"
This same flywheel was also used in 1965/67 Galaxie/LTD's with the 352.
The 390 flywheel (C5AZ6375L) uses a 11 1/2" clutch on a 12 7/8" diameter bolt circle.
The same 390 flywheel was used on cars from 1965 thru 1971, F100/350's from 1968 thru 1976.
Either flywheel will work on a 352, 360, or 390.
The original (1958/70) pilot bearing for all the FE engines was bronze: B8AZ7600A = 1 7/8" O.D. / 11/16" I.D.
In 1971, Ford replaced the bronze bearing with a sealed roller bearing: D1TZ7600A.
In 1978, Ford replaced D1TZ7600A with D8TZ7600A which is also a sealed roller bearing.
The truck in my signature still has its original 352 flywheel.
The original 352 engine was bored and stroked to a 390 in 1982 when the truck underwent a frame off restoration.
__________________
Bill / Retired Ford Partsman 1962-1997 / Ford Historian / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2002 / Cars: 1928/1979
1963 Galaxie 500XL / 1965 F100 Styleside Pickup ~ Original Owner / 2008 Fusion S / 2008 Edge SEL
  #6 (permalink)
Old 01-08-2009, 06:03 PM
if you can i would run the 11.5 clutch vs the 11".
__________________
94 XLT 5.8/E4OD
4.88 gears f/r
Warn HS9500I
Tags
352 , 390
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
