Go Back   Ford Truck Enthusiasts Forums > General > Ford vs The Competition
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
Is F-150 Still King?
  #1 (permalink)
Old 01-06-2009, 08:57 PM
Caleb1 Caleb1 is offline
Caleb1 is gaining momentum as a positive member of FTE.
Chevy engine question
Hey, can someone tell me if the 6.0 and 8.1 liter engines are available in the half ton chevies, what year they became available and does the 5.4 even come close to competing with the 6.0? thanks!
  #2 (permalink)
Old 01-07-2009, 08:38 AM
cleatus12r's Avatar
cleatus12r cleatus12r is offline
cleatus12r has a great reputation on FTE. cleatus12r has a great reputation on FTE. cleatus12r has a great reputation on FTE. cleatus12r has a great reputation on FTE. cleatus12r has a great reputation on FTE.
No, the 6.0L and 8.1 ARE NOT available in half ton trucks. The 6.0L was available in the 1500HD back in 03/04. This truck was essentially a light-duty 2500 with a semi-floating rear axle. The reason for this truck was to get the 4 full-size doors in a "half ton" package since at the time, the regular "half tons" didn't come with 4 doors.
The 6.0 will pretty much blow away a 5.4 when performing roll-ons at 45-50 MPH (once you're already moving). However, from a standstill, it's kind of a toss-up.
__________________
Cody
  #3 (permalink)
Old 01-07-2009, 08:51 AM
97HD 97HD is offline
97HD is starting off with a positive reputation.
Just to add on to that, the 6.0 is available in some 1/2 ton Chevy and GMC trucks as a special option. My buddy has one on his sale lot, it's a 05 GMC 1500 2wd. It was definatley quicker than a 5.4 accelerating, takes off like a rocket and a lot of fun with the traction control off. But for everyday use and towing/hauling I would rather have the 5.4 just because i'm a ford guy. And i think Chevy builds trucks to appeal to a younger crowd as opposed to focusing on a durable and usable piece of machinery.
  #4 (permalink)
Old 01-07-2009, 10:54 AM
Thanks guys. I an just trying to find a reason to buy the more truck looking chevy and a 6.0 in a half ton probably would have sealed the deal, but im not sure if i wanna go with the more truck looking chevy or more truck like ford. I dont care for the newer ford styling but im not sure i wanna take a chance with all the piston slap and weak frame issues. Thanks for your input.
  #5 (permalink)
Old 01-07-2009, 12:34 PM
dkf's Avatar
dkf dkf is offline
dkf has a good reputation on FTE. dkf has a good reputation on FTE. dkf has a good reputation on FTE.
The 5.4l is not a speedy engine in the 150, 250 or 350. It is however a solid motor that will last and will pull quite a heavy load. Will definatly outperform the older 351s. The 5.4l as well as other modulars will rev and like it. In an F-150 I would look at getting at least 3:73 gears. The biggest downfall to any of the modulars is the gearing is too tall. (Like with 3:55s) couple that with the 4spd auto which can lug the motor and performance can feel lackluster. A decnet tune which allows WOT fuel enrichment along with other tweaks can really help.
  #6 (permalink)
Old 01-07-2009, 12:36 PM
Monsta's Avatar
Monsta Monsta is online now
Sit. Stay.
2005 Ford Excursion
Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of
Quote:
Yes, those earlier trucks that had the VORTEC MAX package had a 345hp 6.0L. It now has 367hp 375 lb ft. It is only offered with the LT or LTZ trim level.
The 6.2L offered with the LTZ trim level has 403 hp! Although that is probably running E85.
__________________
Ken
Cats; nasty creatures...
  #7 (permalink)
Old 01-08-2009, 09:34 PM
J..D J..D is offline
J..D is starting off with a positive reputation.
Quote:
Piston slap is old news and weak frame? Ford may have a stronger frame but that doesn't make the chevy weak.
  #8 (permalink)
Old 01-08-2009, 10:29 PM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
Piston slap doesn't really harm the engine anyways. The clearance its still pretty tight, and it goes away once the engine warms up.
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #9 (permalink)
Old 01-08-2009, 10:58 PM
Krochus Krochus is offline
Krochus is gaining momentum as a positive member of FTE.
I've driven em all and in my opinion in terms of performance the closest engine GM has to the 5.4 is the base 4.8L v8, Even the 5.3 leads the Triton around by the nose. It's desperately time for Ford to come up with a new engine
__________________
"It's good to be the king!" ...
King Louis XVI
  #10 (permalink)
Old 01-09-2009, 01:09 AM
thorseshoeing's Avatar
thorseshoeing thorseshoeing is offline
thorseshoeing has a brilliant future thorseshoeing has a brilliant future thorseshoeing has a brilliant future thorseshoeing has a brilliant future thorseshoeing has a brilliant future thorseshoeing has a brilliant future thorseshoeing has a brilliant future thorseshoeing has a brilliant future thorseshoeing has a brilliant future thorseshoeing has a brilliant future thorseshoeing has a brilliant future
Quote:
Pretty sure that's with premium as per the PUTCO test.
The only motor that could match the 5.7 Toyota even though the Toyota could run regular.
Only available with their Crew in a 1/2 ton I beleive.
Tim
  #11 (permalink)
Old 01-09-2009, 01:13 AM
Quote:
Be careful, I recall a member who was saying that years ago. After enough crying from other members, he got booted.
Tim
  #12 (permalink)
Old 01-09-2009, 10:49 AM
dkf's Avatar
dkf dkf is offline
Seems a lot of people think building new engine is always the way to go. I agree Ford needs to step up the power to compete with other makers but it doesn't mean a new engine is needed. There is a lot of power left in the modular platform. The HP increase on the 5.4l for 09' wasn't really acceptable to me, I thought they could have done more. Seems a lot of automakers want to start from scratch all the time and don't bother looking at how they can improve what they have. Retooling is expensive and complete redesigns always have bugs for the first couple years it seems.
  #13 (permalink)
Old 01-09-2009, 11:14 AM
quaddriver quaddriver is offline
quaddriver has a good reputation on FTE. quaddriver has a good reputation on FTE.
Quote:
Originally Posted by Lead Head View Post
Piston slap doesn't really harm the engine anyways. .
It doesnt?
here I always thought it destroyed the piston skirts and ovaled the thrust side of the bore and stuck the rings....(none of which I particularly want in my engine! ;-)
__________________
QuadDriver...
Go Fast, run over sh......stuff
  #14 (permalink)
Old 01-09-2009, 11:30 AM
Personally I think Ford went off a cliff with the OHC motors - the wrong direction for the truck motors. The increase in weight, size, complexity, noise (and problems) IMO is not worth any or all gains. GM took a proven design and fixed the short comings with a clean sheet of paper and has this compact little powerplant. Ford took a proven design and crapcanned it.
A basic tenet of engine engineering was ignored: valve actuation method has no effect on power. The obnly advantage would be to add valves, but adding valves to a truck motor where low end torque is supposed to be the #1 consideration - is foolish.
end result? a 6L+ gm motor can be put in the FWD cars. the 5.4/4.6 are bigger than the PSD. The PSD wont fit in the FWD ford cars. It kind limits your downrange possibilities and handicaps the front end design. If we are to believe that the makers are gonna need to REALLY pay attention to overall package size and front end shape (read: trucks sitting 1 ft lower with rakish hoods) - them GM has a clear advantage.
__________________
QuadDriver...
  #15 (permalink)
Old 01-09-2009, 12:17 PM
No there isn't, Ford's proven that over the years in that there hasn't been a N/A version of a Modular motor that competes with the new generation of v8's or hell even v6'es from other manufacturers. It seems like anytime ford wants to make more than 300hp with a modular they have to supercharge the damn thing or add cylinders.
Hell just look at the Mustang GT, I'm sorry but 300hp from a "performance oriented" 4.6 v8 in 2009 is a Joke. Heck you're about to have a v6 base model camaro come out with the same HP as the Mustang GT. The modular v8 was a dumb idea when it was introduced almost 20 years ago and it hasn't became any more of an intelligent move since.
__________________
King Louis XVI
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
