Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 01-06-2009, 06:11 PM
swinehart07 swinehart07 is offline
swinehart07 is starting off with a positive reputation.
2003 Escape bearings
I did a search but i just wanted to clarify that the front hub bearings have to get pressed out and new ones pressed in. and the bearings can be replaced without having to replace the flange with the wheel studs right? anyone have pics?
  #2 (permalink)
Old 01-24-2009, 10:52 PM
93truck 93truck is offline
93truck is starting off with a positive reputation.
you are correct, they have to be pressed off and on and the whole spindle must be removed to do the work. no special tools needed except a press
__________________
2005 f350 CC/LB/4X4 6.0l AT
  #3 (permalink)
Old 04-27-2009, 01:31 PM
lordoflivernois lordoflivernois is offline
lordoflivernois is starting off with a positive reputation.
and boy is it a pain!
  #4 (permalink)
Old 04-28-2009, 06:26 PM
doing the fronts are a piece of cake compared to the rear, i would do 10 fronts to have to ever do another rear.....
__________________
  #5 (permalink)
Old 05-02-2009, 02:10 AM
Kias Kias is offline
Kias is starting off with a positive reputation.
Quote:
This is why I remove the spindle, take it and a new bearing to the local shop. They charge me 20 bucks to take out the old, and put in the new! Worth every penny.
  #6 (permalink)
Old 05-02-2009, 08:01 AM
Scndsin's Avatar
Scndsin Scndsin is offline
Du Nawt Seek Thuh Treasur
Scndsin is a splendid one to behold Scndsin is a splendid one to behold Scndsin is a splendid one to behold Scndsin is a splendid one to behold Scndsin is a splendid one to behold Scndsin is a splendid one to behold Scndsin is a splendid one to behold
Swineheart hasn't been online since Feb, so I'll ask the rest of yall.
What was it that led to the need to replace the front bearings? I figure it was noise, if so what did it sound like? Or was it vibration, steering issues or tire wear?
Thanx.
__________________
David
94 F-150 XLT 5.8/E4OD SuperCab, 2WD
  #7 (permalink)
Old 05-06-2009, 07:56 AM
My wife started to hear a noise that sounded like a low rumble/growl when she would slightly turn the wheel. for example while going straight and heading towards a gradual rt. curve , when she would turn the wheel to the right the drivers side front wheel would make a growling noise kinda like the noise the brakes would make with worn pads.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
