dual mass flywheel/clutch ?s
If your dual mass flywheel is the problem you will notice vibration and clunking. The vibration and clunking will change at different speeds, similar to a driveshaft or u-joint issue but you will be able to tell that something is badly out of balance.
My 96 PSD had this issue twice, once at 147K miles and again at 196K miles. I traded it with this problem at 199K miles and have wanted another, though not with this problem since it can be expensive to fix.
If you can eliminate the driveshaft and u-joints as the issue it is probably the dual-mass flywheel.
Since it happens at all speeds and when you get on or off the throttle it may just be u-joints. If you've got high miles on it I'd check that first.
Yes, it can very well be the DMF. And it's not expensive to fix. If the springs in the DMF are worn out, or have fallen out it will "whip" around when you get on and off the throttle.
If you finally get to where you are sure it's a clutch, Valair can take care of all of it, and for alot less than anyone else. And even more so if you tell them I sent you. But we'll come back to that.
I would also take a long hard look at your U joints and carrier bearing. Just to make sure they aren't toast.
Does it rattle like hell when you turn the truck off, or when you first start it? If it does, than the flywheel is your problem. If it is, let me know and I'll get you set up with the guys at Valair.
I would definatly say flywheel. When it bucks like that, the dual mass is trying to absorb the spikes of the motor. That's what's causing it to buck. I'm guessing there is alot of slop in the flywheel which makes it worse.
That flywheel is like an auto flex plate with a flywheel tied to it with springs. You can only imagine what that looks like. LOL Sad but true.
PM me if you want the hook up on a new setup.
The DMF can do alot of things. It is a two piece setup with an inner and outer section that is held together with springs and a large bearing race. If the springs just turn loose it will chatter and jerk and thud. If the bearing goes it gets off center and has a terrible vibration that can crack your bellhousing if you keep driving it (seen this). If the springs and bearings go and a spring comes out of the DMF it can get slung through the side of the bellhousing (seen this also).
So as far a slipping, there is not that much real slipping of the clutch because the two parts of the DMF can only rotate so far inside of each other. It is usually the vibration and loud calnks and jerks that get people to cahnge them out.
Plowhand is correct. It is usually the vibrations or clunking. My first DMF went out because half of the bearings misteriously disappeared and it would vibrate terrible every now and then. My second DMF did not go out but the clutch started slipping bad when I accelerated. Wounder if the stage II's had something to do with that? Hmmmm? DOH
Don't want to hi-jack the post but for the last 6 months I've been hearing a faint squeeking sound when I let the clutch out, only audible when the truck is cold. The sound goes away once I've driven a few miles. I have 160k on what I assume is the the original clutch, is there a clutch replacement project in my future?
