Rear seat headrest solution? - Ford Truck Enthusiasts Forums
Old 01-06-2009, 02:50 PM
tj90 tj90 is offline
tj90 is starting off with a positive reputation.
Have a extended cab 1997 F-150. Im looking for an aftermarket solution for headrests for the back seat. The kids are bigger now and their head would hit the glass in an accident.
Im sure someone has asked this question in the past, but Im not returning any hits on a search. I think FTE search function is broken - so please dont flame me.
I checked JCwhitney and did not see anything. Seems that it would be easy to bolt something to the cab behind the back portion of the seat and it would extend up to the glass area.
Regards,
TJ
Old 01-07-2009, 07:31 AM
mjunk1's Avatar
mjunk1 mjunk1 is offline
mjunk1 is gaining momentum as a positive member of FTE.mjunk1 is gaining momentum as a positive member of FTE.
Not a bad idea. Couldn't you get some from a junkyard that match your interior and then just weld up a bracket? Might be the easiest solution. My Screw has headrests on the rear seat, so you might look for one of those in the yards.
Old 01-07-2009, 11:49 AM
Thanks for the idea. I will check the junkyards for a gray seatback with headrests to bolt on...
Old 05-29-2014, 08:21 AM
mauritziii mauritziii is offline
mauritziii is starting off with a positive reputation.
Headrest f150 1997
TJ,
Did you find an answer or a solution? I have the same issue . I was thinking of just making something and having it upholstered. Really don't think it has to be that substantial only a pad so the kids heads do not hit the window.
Marty
QUOTE=tj90;6975516]Have a extended cab 1997 F-150. Im looking for an aftermarket solution for headrests for the back seat. The kids are bigger now and their head would hit the glass in an accident.
Regards,
TJ[/QUOTE]
Rear Seat Headrest options? hwybee22 Excursion - King of SUVs 5 11-19-2015 02:10 PM
1973 F100 bench seat dilemma nblennon 1973 - 1979 F-100 & Larger F-Series Trucks 7 10-26-2015 12:26 PM
Rear seat swap Metz22 1999 to 2016 Super Duty 4 10-09-2015 01:47 PM
Rear seat headrests for extended cab SD? HzrInAz 1999 - 2003 7.3L Power Stroke Diesel 6 08-18-2015 12:00 PM
headrests add on or new seats? Sir Aaron 1999 to 2016 Super Duty 1 07-02-2014 11:52 AM
Tags
2001, 2003, aftermarket, back, backseat, f150, f350, ford, headrest, headrests, rear, screw, seat, tj, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
