Torque Converter Bolts - Ford Truck Enthusiasts Forums
Old 01-06-2009, 10:22 AM
Kazco Kazco is offline
Kazco is starting off with a positive reputation.
1967 F100, 240.
We are in the process of replacing the 3 spd on the column with a c4. We are gathering all the parts and are coming up empty on the torque converter bolts.
Does anyone know where to buy them (searched the local autoparts stores and can only find GM). Part number?
Does anyone know the size?
Thanks in advance,
Mike
PS I tried searching the forums but the search function does not work.
Old 01-06-2009, 12:46 PM
bmuhlbach's Avatar
bmuhlbach bmuhlbach is offline
bmuhlbach is gaining momentum as a positive member of FTE.bmuhlbach is gaining momentum as a positive member of FTE.
try a junkyard for them. the threads are 3/8-24 .or maybe Ford dealer
Old 01-06-2009, 04:51 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK Pro-Street/StateTK is offline
Pro-Street/StateTK is gaining momentum as a positive member of FTE.
Kazco
You are looking for Torque converter ( Nuts )! They are (Jam nuts) or (Jet nusts)!
I'm not sure of the size but I do know a 9/16s wrench fits it. The nuts have a shoulder.
Hope this helps!
Wally Womack
Old 01-06-2009, 07:23 PM
marks69 marks69 is offline
marks69 is starting off with a positive reputation.
i got mine from a performance shop, he had no trouble finding them. i'll look for the receipt and see if i can get the part # off of it.
Old 01-06-2009, 08:36 PM
Redcat Diesel's Avatar
Redcat Diesel Redcat Diesel is offline
Redcat Diesel is gaining momentum as a positive member of FTE.Redcat Diesel is gaining momentum as a positive member of FTE.
A Ford dealer should be able to get them. C6's used the same ones and were built into the mid 90's.
Old 01-06-2009, 08:38 PM
th1567's Avatar
th1567 th1567 is offline
th1567 is starting off with a positive reputation.
Nuts
I'm breaking down a c-6 from a 352...don't need the tranny or the Trg/Con bolts...
If'n they're the same....check around let me know I'll mail them to you, no charge.
TH1567
Drive a Ford or drive home.
Old 01-07-2009, 12:36 AM
bmuhlbach's Avatar
they would be the same all the nuts I have come across are 3/8 -24 which is fine thread.most take 4 my 72 Torino had 8.My 85 c6 is the same as my 65 c4
Old 01-07-2009, 07:20 AM
60F100 60F100 is offline
60F100 is starting off with a positive reputation.
Autozone lists torque converter bolts (they are actually nuts) for a 68 Mustang 289. It is part number 6717 (set of 4) for $14.99
Old 01-07-2009, 08:56 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Note: New Ford part number.
378941S441 .. Locknut-Torque Converter to Flywheel / 3/8" -24 / (378941S441 > > replaced > > 378941S78 & 378941S8)
Ford recommended that these nuts should not be re-used.
MSRP each: $1.58 / FTEpartsguy.com price each: $0.95
If the part number looks "odd" to y'all that recognize Ford part numbers, this is a Ford "hardware" part number aka a standard or utility part number.
Old 01-08-2009, 06:53 AM
Since Bill has come up with a good Ford part number I would use them rather than the ones I found available at autozone. I also agree on not reusing them as cheap as they are. It would not be fun to have a torque converter come loose.
Old 01-08-2009, 06:54 AM
Torque Converter Nuts
Thanks to all, the information was exactly what I needed.
Mike
c6 torque converter install tips/specs jayro88 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 07-15-2014 11:02 AM
Torque Converter Stud Pattern 1972RedNeck Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 02-06-2014 04:57 PM
4r100 drain plug torque spec r___r 1999 to 2016 Super Duty 4 12-15-2013 06:11 PM
flexplate bolts torque jle70 1994.5 - 1997 7.3L Power Stroke Diesel 2 11-14-2009 02:06 PM
Need torque specs for '97 E4OD front pump bolts dominic1964 1999 to 2016 Super Duty 2 08-23-2009 02:36 PM
Tags
2002, 378941s441, autozone, bolts, buy, c6, converter, convertor, ford, nuts, pickup, ranger, specs, torque, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
