Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 01-08-2009, 11:34 AM
C-Leigh Racing C-Leigh Racing is offline
C-Leigh Racing is starting off with a positive reputation.
I dont even want to get started on that bunch of CLOWNS sitting in Washington, theeves, if then aint they will be after they get there.
What happened to the oil subject.
Neil
  #17 (permalink)
Old 01-08-2009, 11:48 AM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is online now
Bear 45/70 has a good reputation on FTE. Bear 45/70 has a good reputation on FTE.
The issue was failures on break-in and that was from the lack of zinc in the oil. Part of the reason I use copious amount of assembly lube and oil with zinc for break-in. Issue two was is synthetic better than dino oil, yes and no. I use it in high heat engines. Like the air/oil cooled engines in my quads, but I tried using it in my 2 stroke race motors and it was tons worse than the dino stuff. Later on the synthetic/dino blends worked well.
__________________
Bear 45/70 Gimp Racing <a href=http://i145.photobucket.com/albums/r206/Bear-45-70/Emoticons/icon_weelchairbb.gif target=_blank>http://i145.photobucket.com/albums/r...eelchairbb.gif</a>
“There are only two things stopping you, common sense and fear! And not much of the latter.”
  #18 (permalink)
Old 01-08-2009, 12:14 PM
Quote:
Ok, you talking about quads & 2 stroke you in my naborhood now & I can relate to that.
Aint much other than eating I like to do better than carving up in a 2 stroke cylinder making at ol boy go fast.
Got a daughter on one been upsetting quite a few BOYs out in the racing world, holding some records anyways.
Neil
  #19 (permalink)
Old 01-08-2009, 03:01 PM
Stevoh's Avatar
Stevoh Stevoh is offline
Stevoh is starting off with a positive reputation.
Well I did buy a 4 qt bottle of the 5w40 stuff. The truck leaks a lot, but one of the main leaks is the oil filter mounting O-Ring. I will put a new one in when I do my next oil change. I poured a little of the 5w40 stuff in, sounded like I was pouring in water into the valve cover haha.
Anyways, I think I am going to go with a 4qt 5w40 + 2 qt 15w40 combo next time. I am over due for an oil change, almost 700 miles since the last one oh my!
Anyways, has anyone used a ZDDP supplement for their oil. I was googling around and recall a product called ZDDPlus that is specifically made for flat tappet motors which need zinc. Anyone ever hear of this?
__________________
1985 Ford F250 Supercab Dually: 460 w/ a C6 and 4.11 gear
1989 Ford Probe GT Turbo and 1995 Ford Probe GT:
http://www.ford-trucks.com/forums/im...ine=1214714627
  #20 (permalink)
Old 01-09-2009, 01:19 AM
ArdWrknTrk's Avatar
ArdWrknTrk ArdWrknTrk is offline
<--Dog is my Co-pilot
ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold
I used the Comp cams additive *and* Rotella when I swapped engines last spring.
Plenty of Crane 'red' lube on the cam and lifter faces when I assembled.
There's less than 10k on it now but I've not seen or heard anything "bad" yet.
__________________
Jim
'87 F-250 4V 460, T19, 4x4, 4.10 sterling 10.25" - Lil' Red
http://i246.photobucket.com/albums/gg117/donjamer/FTE%20Pics/blumax500-1-1.jpgFTE Fraternity of Blue Max
  #21 (permalink)
Old 01-10-2009, 12:10 PM
Jeeps&Fords Jeeps&Fords is offline
Jeeps&Fords is starting off with a positive reputation.
Just interested in why you choose to blend anything?
I'm using the synth Rotella in my diesel and I have started using it in the gas engine in my CJ and it seems to really like it.
The extra zinc is really just for the cam break-in. It won't hurt to run it after break-in but it isn't necessary.
__________________
2001 SuperCrew XLT 5.4 4x4
1987 Jeep Grand Wagoneer 6.5l turbodiesel
1981 Jeep CJ5 Megasquirt'd TPI
  #22 (permalink)
Old 01-22-2009, 10:17 PM
WILDEBILL308 WILDEBILL308 is offline
WILDEBILL308 is starting off with a positive reputation.
I would run the extra additive on break in just for the extra protection and the warm and fuzzy it gives.
I run Mobile 1 in every thing. You might want to go to
Mobil - The Oil That's Changing Oil
and do a little reading.
There is a reason most of the major car company’s BMW, Ferrari, Mercedes all ship with and require Mobil 1.
Bear have you tried this in your 2 cycle?
Mobil 1 MX2T Fully Synthetic 2 Cycle Motorcycle oil
Bill
  #23 (permalink)
Old 01-22-2009, 11:01 PM
Bear 45/70's Avatar
No, I have not, mainly because I have a fairly large supply of the Merc oil that worked so well while racing and since I don't race anymore it is lasting a long time.
__________________
Tags
15w , 40w , co , oil , protection , rotella , shell , triple
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
