Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Early Broncos (1966 - 1977) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 01-05-2009, 08:59 PM
07.5duramax 07.5duramax is offline
07.5duramax is starting off with a positive reputation.
need help with trans install
Hey everybody new to the site here, and I think its great so far! I need some serious help. I have a 72 bronco and I am putting a 351w in it and I need help with installing the transmission! Its the three speed column shift! Dont know much about a trans so I need help any info, PICTURES and such would be great step by step would help alot or if anybody knows a good drivetrain manual for these broncos and where to pick one up would also be great! Thanks for any help.
  #2 (permalink)
Old 01-06-2009, 01:07 AM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE.
Are you just trying to install it, or rebuild it too?
Jason
__________________
"Giggity" Missing your Prius? Check under my tires.
'08 Dodge 2500 MegaCab 4wd, 6.7 Cummins, 6 spd auto, DPF & EGR fell off
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
  #3 (permalink)
Old 01-06-2009, 08:06 AM
Just install, I know it seems minor I have just never messed with a trans much and I bought the truck with the trans sitting on the back seat so I dont have much to go by.
  #4 (permalink)
Old 01-06-2009, 04:39 PM
Frankenstang57's Avatar
Frankenstang57 Frankenstang57 is offline
Frankenstang57 is starting off with a positive reputation.
Easy, install the motor into it's mounts first. You could install the flywheel and clutch before you put the motor in or after. Next, stuff the transmission in. Support the trans and slide the t-case in. Install your x-member. Hook up linkages and misc. stuff. Really quite simple actually. If you have anything more specific please ask. I just got done swapping a 302/C-4 into a 6 cyl model. I also have a V-8 '70 with the 3 spd in it, minus motor. It's on my car hauler and easy to get pix from underneath. Good luck!
__________________
FRANKENSTANG57
06 Ranger
96 F250 4x4
70 Bronco
40 1/2 ton
June 4th is Marvin Heemeyer day!
  #5 (permalink)
Old 01-06-2009, 06:27 PM
RCrawler's Avatar
If if isn't already, you will want to install the adaptor onto the transmission. This will keep the trans output shaft in place.
After you have the transfer case installed, but before the crossmember would be a good time to mount the t-case shifter. You can drop the rear of the assembly down a bit for access.
Don't forget the spacer that goes between the engine and bellhousing. And the pilot bearing in the back of the crankshaft.
Jason
__________________
  #6 (permalink)
Old 01-07-2009, 10:28 AM
whoops, misread...
__________________
FRANKENSTANG57
06 Ranger
96 F250 4x4
70 Bronco
40 1/2 ton
  #7 (permalink)
Old 01-07-2009, 10:23 PM
dodmort's Avatar
dodmort dodmort is offline
dodmort is starting off with a positive reputation.
I find it easier for me to put the T case on the trany while it is down and use a tranny jack to slide the whole thing into place. Always stab it pretty much the first or second time..
This does not work on my one ton very well though.
__________________
24 t (not a sreet rod)
67 gt500 (3rd one)
68 bronco
69 f-250
72 bronco
97 f-350
98 svt cobra
01 hd road king
06 exped.
68 m715-fe,powered - 4 link
Guns, Guns, Guns......."Clarence Boddicker" Robocop circa 1987
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
