Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.8 & 4.2L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 01-05-2009, 08:16 PM
Bricks88 Bricks88 is offline
Bricks88 is starting off with a positive reputation.
4.2 oiling system
Hi everyone. I have a fairly new (rebuilt) 13 k 97 4.2 with no oil reaching the lifters but 70 psi on a mecanical gauge in the oem idiot light location. This problem has also shown up and gone away last week twice.Now its back Im thinking the oil pump relief valve is sticking open,but is the oil preassure fitting before or after the relief valve? any help would be appreciated, Thanks
  #2 (permalink)
Old 01-08-2009, 08:31 AM
bokker bokker is offline
bokker is starting off with a positive reputation.
hi, just checked with the old casting and the relief valve is set into it as an interigal part. the casting is where the oil pump is fastened onto. with the oil pump removed i was able to move the pressure relief valve off its seat and check that is able to move freely under its spring pressure.
i am unable to remember where the take-off is for the oil gauge but if it comes off the oil pump then the pressure is made from the pump then up to the oil gallary to the pressure relief valve.
all a bit iffy but hope it helps. bokker.
  #3 (permalink)
Old 01-09-2009, 04:39 AM
Thank you, bokker It gives me something to think about today.Ill pull the pump tommorrow.
  #4 (permalink)
Old 01-15-2009, 03:26 PM
hi, did you have any luck. bokker.
Tags
42 , engine , ford , oil , oiling , pressure , pump , relief , relif , system , v6 , valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
