Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Other Ford Engines > 401, 477, and 534 SD Engines
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 01-05-2009, 06:53 PM
Jim L. Jim L. is offline
1968 Ford Heavy Duty
Jim L. is starting off with a positive reputation.
Cab and chassis
im looking at aford 10 wheeler cab and chassis with the 534 v8. it has air brakes and manual everything. What model designation would this truck have. Its from the mid 60s best guess
  #2 (permalink)
Old 01-05-2009, 11:56 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
You mean a tandem axle cab and chassis? 10 tires? That's really a 6 wheel, but unless it's 6x6, it matters little.
OK, cab over? Conventional?
C series with 534 would have to be C900 I think. They went up the scale, according to a post here that I am too lazy to look for. 700s got the 401, 800s the 477, 900 the 534---MAYBE. I could be full of beans. But there should be an emblem on the cab, or, the first part of the VIN will tell the tale.
Conventional would be F series, or possibly designated "T" series, for "tandem axle". Again, a 900 methinks.
Tall cabover? Maybe an N series.
Check out these threads...these things are obsolete and not impossible to find parts for, but might be an challenge.
If you are going to put it to work, I'd think twice, three times, how ever many times I had to think about a newer diesel powered truck.
jmo, for the most part.
  #3 (permalink)
Old 01-08-2009, 11:15 PM
94Sport5sp 94Sport5sp is offline
94Sport5sp is starting off with a positive reputation.
Cab and chassis
Hi:
Highway tractors are generally referred to as 18 wheelers because there are 18 tires on 5 axel (including trailer) so I assume you have three axel or a tandem axel truck. If the cab tilts then the truck would be a C series and when there is tandem axel then it is a CT series. A regular cab would be F series with FT for tandem axel. If the truck is a highway tractor then it could be a L, LT, LN, LNT series truck. If still present there should be a tag on the drivers door near the latch and the first letter/letters would identify the series.
These trucks are not known as speed demons but they are known as power houses. There fuel consumption is quite legendary. So the question is how you plan on using the truck.
PaMnd
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
