What kind of antifreeze can I use? - Ford Truck Enthusiasts Forums
Old 01-05-2009, 02:21 PM
DCS1 DCS1 is offline
DCS1 is starting off with a positive reputation.
in my '97 Powerstroke other than something that I have to get at the dealership?
I have researched this site and I am more confused now then I ever was. Can't I just use something that Wallyworld sells and add the FW-15 additive to it?
Old 01-05-2009, 02:25 PM
Eric_F250's Avatar
Eric_F250 Eric_F250 is offline
Eric_F250 is starting off with a positive reputation.
i called the ford dealership just this last friday and asked about the coolant i have- "shellzone".
the fleet manager said that one is okay without adding anything. for heavy duty or industrial applications, they said you'd need SCA, but for our "light truck" it is not needed.
so there is at least one you can get away with.
Old 01-05-2009, 02:39 PM
MADVAN's Avatar
MADVAN MADVAN is offline
MADVAN has a very good reputation on FTE.MADVAN has a very good reputation on FTE.MADVAN has a very good reputation on FTE.
You should use "Low Silicate", then add the SCA.
Bill
Old 01-05-2009, 06:16 PM
live2wheel's Avatar
live2wheel live2wheel is offline
live2wheel is starting off with a positive reputation.
what is "sca". heard a lot of having to add it , what is it? had the guy in the auto parts telling me to check with a hydrometer. now i know thats wrong . he had none (obviously)
Old 01-05-2009, 06:20 PM
MADVAN's Avatar
Old 01-05-2009, 07:52 PM
MADVAN's Avatar
Old 01-05-2009, 08:10 PM
live2wheel's Avatar
this seems more comlicated all the time . rebuilding a motor . easy . modifying it . easy.
putting antifreze in it . well.... thats a different story.
Old 01-05-2009, 08:46 PM
BlueMule's Avatar
BlueMule BlueMule is offline
BlueMule has a good reputation on FTE.BlueMule has a good reputation on FTE.
Quote:
The fleet manager was right, but for the wrong reason
even our "light trucks" need the SCA's but it's already in the Shellzone so it's still the right stuff
Shellzone® Antifreeze is specially formulated to meet the stringent aluminum corrosion protection requirements of today’s automotive engines. Because of its low concentration of silicate, it also complies with Cummins and other heavy-duty diesel engine manufacturer’s silicate requirements. This product is also suitable for use in industrial internal combustion engines where an antifreeze/coolant is required to provide protection against freezing, boil over, and corrosion.
Features and Benefits
Shellzone® Antifreeze provides the following qualities:
• universal formula for both automotive and heavy duty diesel engines (ASTM D 3306 and ASTM D 4985) • excellent heat transfer properties • excellent anti-foam characteristics • excellent corrosion protection for aluminum, brass, copper, solder, steel and cast iron • low silicate formulation • nitrite-free, amine-free and borax-free • concentrate mixes readily with clean tap water • pre-diluted product is ready to use and requires no mixing for top-up and initial fill • compatible with cooling system filters • compatible with heavy duty diesel supplemental coolant additives • compatible with conventional brands of coolant • 100% biodegradable in its pure unused form
Approvals and Recommendations
Shellzone® Antifreeze meets:
• ASTM D 3306 for automotive service • ASTM D 4985 for heavy duty diesel service Shellzone® Antifreeze Prediluted 50/50 meets: • ASTM D 4656 for pre-blend automotive service • ASTM D 5345 for pre-blend heavy duty diesel service
Shellzone® Antifreeze meets or exceeds the requirements of the following specifications: (It should be noted that many heavy-duty diesel manufacturers are changing their requirements to simply require ASTM D 4985)
• AAMVA
• General Motors GM1825M
• ASTM D 3306 incl. D 4340
• ASTM D 4985
• Chrysler MS-7170
• Cummins 90T8-4
• Federal Specification A-A-870
• Ford ESE-M97B44-A
• Mack Truck
• Freightliner
• General Motors GM1899M
(Performance corresponding to GM6038M)
• J.I. Case JIC501
• John Deere H24B1
• John Deere H24C1
• PACCAR
• SAE J1034
• TMC of ATA RP-302A
Note: Shellzone® Antifreeze is not an extended life coolant and requires the use of Supplemental Coolant Additives (SCA’s) in heavy duty and industrial applications.
Old 01-05-2009, 09:09 PM
MADVAN's Avatar
Quote:
Originally Posted by BlueMule View Post
[IMG]• concentrate mixes readily with clean tap water • pre-diluted product is ready to use and requires no mixing for top-up and initial fill •
Rod
The first statement tells me whats in the second statement.
Tap Water. HHmmm.
Bill
Old 01-05-2009, 09:20 PM
FARM69's Avatar
FARM69 FARM69 is offline
FARM69 is gaining momentum as a positive member of FTE.
Haha Bill.
So what your saying it doesn't readily mix with well water? lol
Old 01-05-2009, 09:37 PM
Eric_F250's Avatar
okay, to re-complicate what we just simplified... will the ingredients of the shellzone break down to the point where supplemental coolant additives will be needed someday?
Old 01-05-2009, 09:42 PM
MADVAN's Avatar
Quote:
Originally Posted by FARM69 View Post
Haha Bill.
Water is not just water.
Depends also what your location adds to it.
At the shop--All gets the garden hose.
People will overpay to drink bottled water but
they wont do it for their cooling system.
No tap,well ect water for me.
Have seen what it does.
Check the non-laboratory use in link.
Purified water - Wikipedia, the free encyclopedia
Bill
Old 01-05-2009, 09:50 PM
MADVAN's Avatar
Its pre-charged.
You still need to test down the road.
Bill
Old 01-05-2009, 09:52 PM
FARM69's Avatar
Nice link Bill. I usually fill mine up with the garden hose because I'm too cheap to buy destilled.
Eric, I believe the SCA will last the lifetime of the coolant. You can probably buy some test strips to check it after a while.
using wd40 rather than starting fluid natedowney Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 11-20-2014 05:44 PM
Aux switches, what and how??? Clover_SD 1999 to 2016 Super Duty 4 08-20-2013 01:55 PM
1976 F150 Ranger 4x4 bumper options 76rangerF150XLT 1973 - 1979 F-100 & Larger F-Series Trucks 2 01-15-2013 06:52 PM
synthetic trans oil dadirtydogg 2004 - 2008 F150 16 03-26-2008 09:40 PM
brake bleeding with proportioning valve??? kilog55 1973 - 1979 F-100 & Larger F-Series Trucks 23 02-14-2008 10:18 PM
Tags
07, 2002, 73, antifreeze, degas, ford, googlegooch, kind, low, powerstroke, replacement, silacate, tank, wikipedia, windstar
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
