Fuel Filter replacement ('06 F-250 5.4L gas) - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-05-2009, 01:11 PM
stevenn1's Avatar
stevenn1 stevenn1 is offline
stevenn1 is starting off with a positive reputation.
Question Fuel Filter replacement ('06 F-250 5.4L gas)
Dealer says at 30k miles it needs to be replaced. But they want $54. Seems a little high priced to me. I replaced one on my old '88 F-150 I-6 gas for $10 years ago and it was not hard. So is this one for the dealer or can I do it? What special tools do I need and what do I need to know? Where is it located?
Old 01-05-2009, 01:31 PM
ironmine ironmine is offline
ironmine is starting off with a positive reputation.
My truck is a 2002 F250 5.4 .... but if it helps any.. my fuel filter was mounted on the inside of the driver's side frame rail. It does take a special disconnect tool for the fittings, which I borrowed from Advance Auto when I bought the filter.
I did not try to do it without the tool. I think I will just buy the little tool next time. Anyway ... easy job.
Old 01-05-2009, 02:28 PM
Mustang6147's Avatar
Mustang6147 Mustang6147 is offline
Mustang6147 is gaining momentum as a positive member of FTE.
I have an 06. It Does "Not" take any special tools. When you look at the hose that connects to the filter you should see a color plastic peice. You squeeze that peice and push the fitting toward the filter, then pull it off.
Becarefull of fuel pressure and gas coming out. (Safety Glasses)
They went to a new style clamp and the good thing about it is if it breaks it can be repaired very easily.
I used a NAPA filter on mine $13.00 or so. I really like NAPA parts. I have gotten my fair share of garbage from Advance and Twilight Zone. Enough to learn my lesson and not go back unless its for Air freshoners or cars washes/wax.
Using the old style tool can mess up the fitting
Old 01-05-2009, 02:32 PM
motown's Avatar
motown motown is offline
motown is starting off with a positive reputation.
If you let it sit overnight , before changing the filter, the pressure will bleed down. Just don't pry on the blue clip. I have a Reg cap 05 and working room is kinda tight, changing the filter.
Old 01-05-2009, 02:40 PM
Yea now that you say that motown, it was tight. I think I had to undo a bolt that holds the filter to the frame, and the fuel lines where still a mother.
Old 01-05-2009, 04:54 PM
I don't buy repair parts at Advance either, but things like filters and elements they stock Motorcraft OE, Purolator Premium, Purolator, and Fram .... in addition to off name. Exact sparkplug you are looking for, etc
Old 01-05-2009, 06:12 PM
Ironmine, I didnt mean to sound confrontational. I reread my post and can understand it can be taken wrong. I assure you it wasnt intended.
Old 01-05-2009, 07:41 PM
stevenn1's Avatar
Around here it is mostly AutoZone & O'Reilly auto parts stores. Thanks for the info.
Old 01-05-2009, 10:45 PM
dstig1 dstig1 is offline
dstig1 is gaining momentum as a positive member of FTE.
Yep - no tools needed on my 05 either. But it was a PITA to get the d%#n filter out of it's bracket. The flexible lines are so short, they don't easily bend enough to slip one off. Would have been much nicer if the bracket split open so you could slide the fliter right out, but that's life. I unbolted the bracket to give me as much flex as I could, and it was still a fight.
To drain fuel pressure, start the truck, and pull the fuse for the fuel pump while it is running. It will die in a second or 2 relieving pressure. I've also done this by disconnecting the fuel pump impact/cutoff switch or just giving it a thump with your fist to pop it out. Whatever suits you. Still a lot of fuel will spill out as you disconnect the filter, but it won't spray like mad. Just have a couple cups or small pan to catch it.
Old 01-05-2009, 11:09 PM
Quote:
No worries.
Pull and replace 5.4 3v gassplant 2004 - 2008 F150 1 04-27-2014 07:23 AM
P0112 Code for 5.4L V8...need help please jebee758 1999 to 2016 Super Duty 8 12-18-2012 02:36 PM
just replaced alternator and belt - not happy with results djtrackie 1997-2006 Expedition & Navigator 15 06-25-2008 08:57 PM
2006 f150 get 10mpg jodeben 2004 - 2008 F150 10 03-15-2008 07:25 AM
06 F250 5.4L has no power or gas mileage. wolfehunter 1999 to 2016 Super Duty 15 11-06-2006 07:30 PM
Tags
01, 05, 2006, 54, 54l, change, changing, check, f250, filter, ford, fuel, location, motor, pressure
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
