Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 01-05-2009, 12:03 PM
timmyt22 timmyt22 is offline
timmyt22 is starting off with a positive reputation.
256 y block
Pulled apart my 55 F-100 272 with g heads and both were cracked, left side was there for a while. My question is on a 256 Mercury I found.
Was wondering if my crank from the 272 will work in the 256 Merc making it a 272 again with the longer displacement? The casting letters were EBY and the heads had a 4 barrel manifold on it, though someone adapted a 2 barrel carb. Can this block be punched out to a 292 standard like the 272?
Couldn't get to the head letters but from my research looks like it came out of a 54 Merc with a 4 barrel. Has a monster looking auto trans hooked to it now, I have a 3 speed w/od that came with my truck I run.
My 272 with the ECZ-G heads, stock ignition and 2 barrel, ran pretty good and I did not want to do all this work and end up with any less performance. Was going to run a newer 4 barrel and distributor on it, and stock manifold and heads ( looks like they are EBY to). Is it worth all the trouble, or should I just go get some good G heads?
  #2 (permalink)
Old 01-08-2009, 12:16 PM
pcmenten pcmenten is offline
pcmenten is starting off with a positive reputation.
The -G heads are the best heads made for the Y-block. But if you're running a stock cam, you might get the same performance from -C or other heads.
Yes, you can stroke the 256 to 272.
__________________
Best regards,
Paul Menten
Tags
256 , block , engine , mercury
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
