Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007 and Newer Expedition and Navigator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2007 and Newer Expedition and Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
Is F-150 Still King?
  #1 (permalink)
Old 01-05-2009, 10:04 AM
hjsimpson's Avatar
hjsimpson hjsimpson is offline
hjsimpson is starting off with a positive reputation.
Frozen Driver and passender windows
Hey Folks,
I was wondering if anyone was having a similar issue with frozen driver and passenger side windows due to frigid temps even after a 20 minute warmup with the heat on. I can hear the motor trying to open the window but it just doesn't
It's happened 3 times in the past month.
They eventually free up but its pain in the butt when you need to show your badge to base security.
__________________
2007 Ford Expedition XLT 4X4
Options: Black with Tan Leather Seats & Rear Aux Air
Modifications:
Husky Liners Molded Mud Guards
Ford OEM Low Profile Bug Shield & Side Window Deflectors
WeatherTech Floor Liners & Cargo Liner
Tinted front windows
Quote:
Never, never, never give up. -Winston Churchill
  #2 (permalink)
Old 01-05-2009, 12:29 PM
gristanv gristanv is offline
gristanv is starting off with a positive reputation.
Cool
Yes, I have the same problem on my 2007 EB.
  #3 (permalink)
Old 01-05-2009, 12:50 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is starting off with a positive reputation.
They probably used an inferior grease that hardens at low temps. Take it back.
__________________
2008 Expedition Eddie Bauer 4x2
1978 F250 Lariat 4x2
  #4 (permalink)
Old 01-05-2009, 09:27 PM
gpfarrell gpfarrell is offline
gpfarrell is starting off with a positive reputation.
Is the glass freezing to weatherstripping or is the mechanism binding?
I'd bet it's the glass. Try spraying silicon on every edge of the weatherstripping that touches the glass and you'll probably be fine.
I used to wash cars (for $) outside all winter long. If I siloconed the weather stripping nothing ever froze shut.
  #5 (permalink)
Old 01-05-2009, 10:34 PM
YoGeorge YoGeorge is offline
YoGeorge has a good reputation on FTE. YoGeorge has a good reputation on FTE.
Yup, lube the weatherstrip...
Saw this post earlier and gpfarrell beat me to the answer.
Lube the weatherstripping with silicone spray and they won't freeze shut. Might smear the glass a bit, but they'll open.
You'd have to fill the door full of water to freeze the regulator mechanism.
George
  #6 (permalink)
Old 01-06-2009, 11:31 AM
berry1234's Avatar
Easy test. Pour some luke warm water on the window where it meets the seal. If it helps, its the seal, if not its the motor.
__________________
  #7 (permalink)
Old 01-07-2009, 09:58 AM
tirnaog tirnaog is offline
tirnaog is starting off with a positive reputation.
Aye this has happened to me too.
That silicone spray, can be found at local car stores?
  #8 (permalink)
Old 01-07-2009, 10:09 AM
Sure, it should be easy to find at any auto parts or hardware store...it's quite common and otherwise useful around the house.
In addition to the window weatherstripping, a bit on the door weatherstripping can help if your doors tend to stick shut when icy. For the door weatherstrip, I'll just spray some on a rag and do a wipe around the perimeter.
Another great use is to spray your snow shovel and the chute of your snowblower with it--that sticky wet snow won't stick as badly.
George
  #9 (permalink)
Old 01-14-2009, 07:36 PM
flyboy5111 flyboy5111 is offline
flyboy5111 is starting off with a positive reputation.
Mine does the same. The motors seem weak. My 04 F150 never did this.
__________________
Nothing but Ford.
  #10 (permalink)
Old 01-23-2009, 03:48 PM
Bopper's Avatar
Bopper Bopper is offline
Bopper is starting off with a positive reputation.
Mine is 2 days old and they seem weak. Yes, it has been cold though.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
