I don't think it's as cool as you might think it would be.
Civil Engineering consists of a lot of arguing with wetlands commissions and all that garbage.
My uncle is a civil engineer. They offered him the job of town engineer for his town. He told them no thanks he couldn't afford the pay cut right then.
The good news is that civil engineers don't spend all day inside. They can write off their mileage because they're constantly driving around checking on jobs they designed and they make 6 figures.
There are many different kinds of engineers. What about mechanical engineering? Randy is a mechanical engineer, and I have two uncles that are mechanical engineers. One works for Martin.
__________________ Lisa Early '99 PSD long bed XLT supercab. 4" Pro Comp suspension lift, 315 BFG AT's on 17" Liquid Metal Gatlins, Hypermax Boost Pyrometer, 4" exhaust, DP Tunes - no start, 60 Tow, 80 Econo, 120 Race, 203* thermostat and billet housing, 6637 w/Pete's cover, CCV, oil crossover Kit.
Jim can you elaborate on what exactly a spider web cradle is?
On your design you have the box attached at 4 points. That means that the force of the impact is going to be devided by 4. If you attach it by 6 or 8 points and all the tubes are interconnected the force is spread out.
Ok what weighs more in psi a fridge or a water bed?
__________________
Jim
2001 F350 4X4 DRW
Bilsteins, 4" Turbo Back Into 6" Stacks, 6637 w/,Custom Cold Air Intake ,Autometer guages, DP TUNER http://www.roadsidehelpnetwork.info/
PAA # 14 RIP Mark.. I'll never forget you!!
Yea. However I don't know the measurements and weight of a fridge or waterbed off the top of my head.
Well the pounds per square inch is determined by how much pressure an object is exerting per square inch of surface area it has.
If you had a gallon of water in a 1 square inch column then the pressure at the bottom of the column would be 8psi since a gallon of water weighs 8 pounds.
The fridge has less surface area so it's exerting more force on the area it is sitting on.
However if you tilted the water bed on its end it would be exerting far more pressure than the fridge. You're assuming the water bed is laying flat.
No measurements needed Pete. Even though the fridge is smaller and weighs less than the water bed, it weighs more in PSI. The fridge sits on 4 small feet so all of the weight is on those four small points. A waterbed is much heavier but the weight is distributed over a much larger surface area so in psi it weighs less.
__________________
Jim
2001 F350 4X4 DRW
Something along those lines?
Bingo.
To be fair the only reason I knew the answer to that..is that I live with an engineer..and I am always getting speeches about various theories and laws that govern specific truths in everyday life.
