Blowing Oil
Blowing Oil
Just put my 460 together now i have major oil leak ?? New edelbrock performer rpm , New 770 Holley , New voodoo cam lifters springs retainers Ect. My question is i think the oil is leaking from rear of intake i used new valley pan BUT didnt use the front or rear rubber strips instead used a very heavy bead of { rtv } this is the first time i ever used rtv instead of rubber gaskets . Do you guys use gaskets or rtv ??? Also after changes i have oil blowing out around oil dipstick never had this problem when engine was stock !! I am useing PCV valve and vented oil cap but it seems i have increased the crankcase pressure any ideas on better venting ???
I've always used RTV instead of end seals with aluminum manifolds.
Are you sure the oil pressure sender is not leaking at the back of the block?
*edit* I'm pretty sure Edelbrock says specifically to only use their 7223 gaskets with the Performer-RPM. (no tin pans)
X2 on giving your rings a chance to seal...
