Fuel Mileage misunderstanding Any valuble info
no, we are talking about a truck with a lot of modifications that gets 8 mpg.
if you are happy with getting about half the mpg you should be getting then do not listen to suggestions like mine.
the jacobs box is really a band aid on your truck, it is firing those crappy trick bosch plugs and i would bet if you pulled them at least half are fouled.
do what you want but my truck gets 15 mpg in the city and your does not.
on
OK.. so forget the fancy diagnostic tools, does it flash codes on the check engie light if you ground the STI wire and turn the key on? This will tell you if the computer has lost it's marbles or not, if you get codes.. any codes at all it's probably fine, and if you do then you have a starting point at least.
quicklook, are the bosch plugs really that bad? I havent had anything but them in my truck, so I wouldent know of it acting any different. Sounds like maybe I should change em out. Even though mpg doesnt really concern me from the sounds of it they probably will make it run a whole lot better.
i never said i got 15 mpg in the city with a 90 351.
i said i got 15 mpg in the city in my truck, 94 auto 4.9 long bed driven like it has an egg under the accelerator.
plenty of 15 mpg in the city from a bunch of members here with v8s and sixes.
now if i had said 20 mpg....
393 Stroker, I havent had time to try the back probe yet. Im going to my shop this weekend and ill try it then. I am wondering if maybe my O2 could be shot and by not throwing a code if the computers dead its not operating at full circut. I have a few diagnostics to run this weekend and get a new fuel filter but I guess we will see.
And as for quicklook2. You drive a 4.9 and you are lectureing me on my plugs. They wouldnt help you becuase you drive a six man, your getting 15 in town when I have heard of others getting 17 so dont be so quick to judge what you think. Im sorry but a six is completely different than a v-8 no matter what you are looking at. the only similarities is they use spark plugs and have ford stamped on the case.
#28
#30
