Hard steering? - Ford Truck Enthusiasts Forums
Hard steering?
Old 01-04-2009, 04:02 PM
rblaine9000's Avatar
rblaine9000 rblaine9000 is offline
rblaine9000 is starting off with a positive reputation.
Question Hard steering?
Well, I have new gearbox and hydo-boost, must be the pump? The pump is the last thing to change! I drove my friends truck it was an 01 and it turned like a car and mine is still stiff, now does anyone have any suggestions on pump? where to buy etc...
Old 01-04-2009, 05:45 PM
rugermack's Avatar
rugermack rugermack is offline
rugermack is gaining momentum as a positive member of FTE.rugermack is gaining momentum as a positive member of FTE.
Did you check your steering stabilizer ?
Old 01-04-2009, 05:53 PM
Douglas DC-9's Avatar
Douglas DC-9 Douglas DC-9 is offline
Douglas DC-9 is starting off with a positive reputation.
Nope, it's a classic issue for the later 7.3's! I spent over 8k trying to fix this problem with one of my trucks and just gave up. I had replaced everything except the steering wheel with no luck. Tie rods, ball joints, power steering pump (twice), hydro booster, hydro booster lines, axel shafts, 4x4 hubs, gearbox (twice), brakes pads, calipers, and rotors.
Correct me if I'm wrong, but if you have the truck in park and rev the engine up the problem goes away. But if you have your foot on the brake, or engine at idle its next to impossible to steer the truck, right? I am so fed up with it when I was backing trailers into my shop I don't even use the truck for much anymore. On top of hard steering while trying to park, imagine having a 9'2" Boss V-Plow hanging on the front to make things even harder.
Old 01-04-2009, 06:12 PM
Did you use tranny fluid or power streering fluid
Old 01-04-2009, 07:09 PM
mattpowerstroker mattpowerstroker is offline
mattpowerstroker is starting off with a positive reputation.
i had my pump replaced friday and still the same problem. drove around the block and brought it right back to ford. The diesel guy who put it on told me it was cause i was running to big of tire for it. i asked what kind of bs is that so they checked everything out and couldnt find any problems so going to undo the steering stabilizer tomr see if it is the problem.
Old 01-04-2009, 07:20 PM
sflem849's Avatar
sflem849 sflem849 is offline
sflem849 has a good reputation on FTE.sflem849 has a good reputation on FTE.
Quote:
It shouldn't matter FWIR the ATF is only bc it runs quieter, not bc it is better for the system.
Old 01-04-2009, 08:53 PM
Quote:
well in that case the only thing for me to do is change the pump! yah......
Old 01-04-2009, 09:46 PM
Mr. Bob's Avatar
Mr. Bob Mr. Bob is offline
Mr. Bob is starting off with a positive reputation.
Yep... I have had this problem with mine now since I bought it... I remember reading somewhere about a high volume pump??? Can't find the link now....
Old 01-04-2009, 10:03 PM
John7894's Avatar
John7894 John7894 is offline
John7894 is gaining momentum as a positive member of FTE.
This one? I've got the same problem too.
Here's the link to the pump from AGR. I think Autozone can get it. maybe other auto parts stores can as well.
Welcome to AGR Perfomance, Inc.
Old 01-04-2009, 10:38 PM
BigF350a BigF350a is offline
BigF350a is starting off with a positive reputation.
Hey just wondering. How the rest of the front end components?? Ball joints front steering u joints?? You don't have anything ceased, or ball joints
that have been tightened to much?? I have also seen alot of bad rebuilt steering boxes. How big of a tire are you turning..
Old 01-04-2009, 11:55 PM
Oh, I forgot to tell you guys how much better this gets.... after I spent all this money trying to fix this truck the service manager, Jon hands me a printed page off of his computer from Ford. He had highlighted my problem of hard steering and underneath, where Ford's fix for the problem he had highlighted "....there is no fix for this problem."
The only thing that I've been told to do is buy and install a hydraulic steering assist kit. Haven't gotten to that yet, but I'll let you guys know if I ever do.
Dan
Old 01-05-2009, 05:52 AM
All componets are tight and new!Factory size tires 265's
Old 01-05-2009, 05:54 AM
Dan[/quote]
I thought that was the hydro-boost? My truck has this!
Old 01-05-2009, 06:02 PM
I was thinking something more along the lines of this
hydrosteering
Old 01-05-2009, 07:59 PM
sflem849's Avatar
Nope, hydroboost provides power brakes bc your truck doesn't burn gas (thank goodness) nor the vaccum normally used for power brakes.
Fuel pump problems therigwelder 1994.5 - 1997 7.3L Power Stroke Diesel 2 10-02-2016 01:34 AM
Power steering pump Cjohnson80 1968-2013 Full Size Vans 8 06-16-2016 09:27 AM
2003 f-250 v10 fuel pump??? MDSLIGHT 1999 to 2016 Super Duty 0 11-01-2015 11:08 AM
Fuel pump rangergirl94 1987 - 1996 F150 & Larger F-Series Trucks 17 04-26-2012 08:11 AM
Electric Vs Manual fuel pump? OARfan 1973 - 1979 F-100 & Larger F-Series Trucks 6 12-22-2010 01:32 PM
Tags
01, 2002, 2003, 4x4, 73, banks, brake, diesel, dually, f150, f250, f350, ford, forum, granite, hard, mack, pads, powerstroke, put, steer, steering, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
