Hard steering? - Page 2 - Ford Truck Enthusiasts Forums
Hard steering?
Old 01-05-2009, 08:14 PM
camodown's Avatar
camodown camodown is offline
camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.
the obs trucks used a vacuum pump that was belt driven to run the steering and it wasn't tied into the braking system. The old truck i had could steer perfect when stopped. This one no such luck. The heavy duty chassis (commercial) obs had hydroboost. My truck has the same problem as you. The steering box is a redhead, the pump is a reman Ford, the ball joints are good, the hubs are newer, the steering stabilizer is newer, and I just got an alignment. Still won't really steer when stopped. I just learned to live with it... The problem with aftermarket pumps such as PSC and AGR is the hydroboost is the 'bottleneck' in the system. The hydroboost unit can only flow so much, and as it stands is pretty much at capacity. You could find someone to bore it out then get an upgraded steering pump, but it will die faster if you run a stock hydroboost.
Old 01-05-2009, 08:27 PM
rblaine9000's Avatar
rblaine9000 rblaine9000 is offline
rblaine9000 is starting off with a positive reputation.
I hate to hear all of this info because my friends 01 turns and drives like a half ton! and My truck is better than it was but not perfect. I was hoping to find out that the pump would do it! I am going to waste some money and try the pump soon and let you guys kn ow! furthermore I am going to replace with synthetic tranny fliud...
Old 01-05-2009, 09:21 PM
Douglas DC-9's Avatar
Douglas DC-9 Douglas DC-9 is offline
Douglas DC-9 is starting off with a positive reputation.
My 6.0's don't do this, and turn like a half ton. Then again, they don't have many miles yet. My highest milage 6.0 is only at about 80k.
Old 01-06-2009, 05:58 PM
mattpowerstroker mattpowerstroker is offline
mattpowerstroker is starting off with a positive reputation.
i took my steering stabilizer off today and was just wondering how hard it should b to push in.This thing is as hard to pushin as on of my shocks on the truck. I dont think it should b that hard. Havnt been in a parking lot to see if that is what is the problem but sitting still in my shop it turns alot easier.
Old 01-06-2009, 06:03 PM
Quote:
My truck does'nt have a stabilizer shock on it though so that is going to be no help. I have read some people have had good luck with the pump change. also my friends 01 has the shock? so it should'nt matter but I think that it might be the fluid and pump!
Old 01-06-2009, 07:04 PM
camodown's Avatar
the steering stabilizer won't affect difficulty in steering unless it is done for or bent. It just dampens quick changes in direction such as bump steer so the steering wheel doesn't jerk...
Old 01-07-2009, 06:26 PM
I replaced my pump and guess what? My truck turns easier and steers easier as well! I think this is as good as she gets.....anyways just wanted to let you all know.
Old 01-07-2009, 07:37 PM
camodown's Avatar
Sounds like a good deal! Did you get a Ford remn or other?
Old 01-08-2009, 08:27 PM
sflem849's Avatar
sflem849 sflem849 is offline
sflem849 has a good reputation on FTE.sflem849 has a good reputation on FTE.
Quote:
Talk to us in about 8000 miles...I bet it is back again.
I don't want to be a negative person/basher, but I have heard a few stories about this happening and I am one of them. Good Luck!
Old 01-08-2009, 08:56 PM
aldridgec's Avatar
aldridgec aldridgec is offline
aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.
THe pump that was on my truck when I bought it exhibited none of the typical problems. However, it was noisy when cold so I replaced it. Guess what, hard to turn when braking.
Something up with the pump. Maybe initially it's ok, hopefully it will be forever. Second pump since then and it didn't make a difference.
Old 01-08-2009, 10:24 PM
sflem849's Avatar
So you had the same thing Chris? It sure does blow! Try to back a 25' gooseneck in a crowded fairgrounds with it...or the 90 degree boat launch at one of my favorite lakes...
Old 01-08-2009, 11:20 PM
aldridgec's Avatar
I have.... well close enough to a 25' gooseneck. I'm researching cheap alternatives to fix this, but I'm waiting on my replacment ecm right now.
I was so happy when I got the truck and it didn't have the steering problem. If figured something was different about a 2002 that I had seen in earlier model 7.3's. Wrong, just had a decent pump. What's worse is the pump I have now, is noisy.
  #28
Old 01-09-2009, 03:43 PM
matty169 matty169 is offline
matty169 has a good reputation on FTE.matty169 has a good reputation on FTE.
Try this
It works on the Super Duty also. Ideally you should enlarge the passages in the hydroboost as well to 5/8 inch, as that is the bottle neck after this mod.
  #29
Old 01-19-2009, 10:01 AM
Capt.Schenk's Avatar
Capt.Schenk Capt.Schenk is offline
Capt.Schenk is gaining momentum as a positive member of FTE.
I'm having problems steering too. Was there any conclusion to this thread? I have 280k miles on the truck now, and my problem started at about 240k miles. Luckly I have a manual tranny, so in parking lots I can push in the clutch and rev the engine to turn easier. Should I try a new pump? Is there any advantage to buying a new pump with the reservoir? The reservoir isn't too hard to swap between old and new pumps, is it?
  #30
Old 02-07-2014, 04:23 PM
Bonanza35 Bonanza35 is offline
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
Like to here the end to this.
Fuel pump problems therigwelder 1994.5 - 1997 7.3L Power Stroke Diesel 2 10-02-2016 01:34 AM
Power steering pump Cjohnson80 1968-2013 Full Size Vans 8 06-16-2016 09:27 AM
2003 f-250 v10 fuel pump??? MDSLIGHT 1999 to 2016 Super Duty 0 11-01-2015 11:08 AM
Fuel pump rangergirl94 1987 - 1996 F150 & Larger F-Series Trucks 17 04-26-2012 08:11 AM
Electric Vs Manual fuel pump? OARfan 1973 - 1979 F-100 & Larger F-Series Trucks 6 12-22-2010 01:32 PM
Tags
01, 2002, 2003, 4x4, 73, banks, brake, diesel, dually, f150, f250, f350, ford, forum, granite, hard, mack, pads, powerstroke, put, steer, steering, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
