94/96 CPS in a 97?
on
1 Post
Yes it will work but the 97-03 truck also have their own $15 CPS. Check ebay. BUT be warned that some trucks don't like the new cheap sensor. Even though its a recall replacement for the old black sensors it has its own major issue when used on some trucks but it hit and miss
It'll work, I've used a 97 CPS in my 96. The only difference is the terminals on the early ones were tinned and the late ones are gold plated to be OBDII compliant. There's a possibility of galvanic corrosion between the two dissimilar metals. If you're bothered by that you should be able to get the 96 and later CPS for about the same price.
cbr600rx7
18
09-28-2021 02:20 PM
f100beatertruck
27
03-17-2012 01:43 PM
