Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 01-04-2009, 10:23 AM
wagonwrench wagonwrench is offline
wagonwrench is starting off with a positive reputation.
cylinder head identication Y-Block 292
Can you identify what type of cylinder head you have while head is on block? Would you have to remove them to Id?I know a fellow that has several Y-blocks, would like to get ECZ E-F heads.
  #2 (permalink)
Old 01-04-2009, 12:09 PM
46yblock 46yblock is offline
46yblock is starting off with a positive reputation.
Yes. Go to FORD Y and read the section on head ID. Then have a rag, solvent, mirror, and good eye glasses ready for use.
__________________
1946 1/2 ton with 305 cu in Y-block
1990 Ranger 4WD
  #3 (permalink)
Old 01-05-2009, 01:24 PM
Y-Blockhead's Avatar
Y-Blockhead Y-Blockhead is offline
Y-Blockhead is starting off with a positive reputation.
Wagonwrench,
If I am reading your question correctly, you are looking for ECZ E-F heads?
I cannot say I have ever seen ECZ followed by E or F's. ECZ-A, B, C and G and the normal ID.
Are you talking about E or F code ENGINE heads? An E code car/engine (dual quad) would have ECZ-G heads. And F code car/engine (supercharged) would have a head with a lower compression ratio. Don't know ID, I think the 113's were replacement heads tho.
But check the site 46yblock suggested for the most extensive list of Y-Block Heads.
  #4 (permalink)
Old 01-06-2009, 05:59 PM
cylinder head id
Y-Blockhead, after checking numbers, you are correct in what you say. Have a C2AE block with C heads would like to get a set of the ECZ heads and 4 barrel intake to up power when we rebuild it. Thanks for your help.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
