1978 - 1996 Big Bronco
Big Bronco FAQs
Old 01-10-2011, 02:18 PM
JERSEY MUD's Avatar
JERSEY MUD
JERSEY MUD is offline
wow
im so glad i found this site as i will be converting my 96 bronco to a half cab
  #47
Old 03-12-2011, 12:07 PM
scollet's Avatar
scollet
scollet is offline
hey man im new to the site and not trying to be a cocky or anything but u need a picture of my truck on those faqs...look at my avitar pic and tell me what u think
  #48
Old 03-12-2011, 04:32 PM
greystreak92's Avatar
greystreak92
greystreak92 is offline
The Centurion has a site all its own. www.fourdoorbronco.com The Centurion (and a few other) conversions began life as F-series crew-cab trucks with the Bronco bed worked in place of the pickup bed.
  #49
Old 03-20-2011, 07:37 PM
4bbryan's Avatar
4bbryan
4bbryan is offline
I replaced my 1994 XL (302) ECM and coil. No spark. What did I miss or do wrong?
  #50
Old 03-20-2011, 08:42 PM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is online now
You'll do much better to start a new thread in the main forum. This isn't the place for tech questions.
You'll get much more help and better responses there.
  #51
Old 06-25-2011, 07:16 AM
kellie's Avatar
kellie
kellie is offline
radiator interchange 81 bronco
HI, i'm wanting to know what other yr bronco or f series radiator will fit in my 81 full sz. ? appreciate your help, thanks
  #52
Old 06-25-2011, 07:34 AM
greystreak92
Kellie,
Best to start a new thread in the Big Bronco Forum. Your question won't be seen here.
  #53
Old 07-25-2011, 06:49 PM
R.England's Avatar
R.England
R.England is offline
i just got a 1983 Bronco. I was looking to get some advice and maybe see if i could get some help. this truck has sat up for ten years and im kinda scared to jump in head first. it first had a 6 banger in it. im glad it had a 351M trasplant. i am just woundering if there is anything i should be midful of with this trucks age. when i first started to mess with it i was worried that the clutch would be froze up. i guess i dodged a bullet when i put it in natual and i started to roll. i went to crank it and i was suprised that it fired right up. ive dropped the tank and removed the old fuel it had a very pungent odor to it and it came out black and it slight orange tint to it. i took a light looked in the tank and there was trash all in the bottom of the tank and i took a presher washer and spayed all the trash out and it was one of the cleanest fuel tank ive ever seen. saddly i have ran in to a problem with a set of long tube headers. when i hooked them up on the drver side my frount drive shaft is hitting my headers. im just looking for some help. thanks
  #54
Old 11-12-2011, 10:06 PM
georget's Avatar
georget
georget is offline
78 BIG Bronco wireing prob.
Hello, i am very new here but i like what i have read so fare. im having an ignition, voltage regulator, solenoid prob. not really sure where. need help please
  #55
Old 11-12-2011, 11:26 PM
nixvet2000's Avatar
nixvet2000
nixvet2000 is offline
wire prob
What are your symptoms?
  #56
Old 11-12-2011, 11:35 PM
georget's Avatar
georget
georget is offline
i hook up the battery and the starter engages, and the key is off. i replaced the solenoid sweats, ignition, and now it tries to start on its own.
  #57
Old 11-13-2011, 01:15 AM
nixvet2000's Avatar
nixvet2000
Check/replace your neutral safety switch or call ghostbusters.
  #58
Old 11-13-2011, 08:43 AM
georget's Avatar
georget
georget is offline
Thanks, but I don't think that a 78 bronco had that yet. I think I mite have wires crossed or something. I don't have a good memory now, its a medical thing, just asking for someone to maby tell me where the wires go. Please and thank you.
  #59
Old 11-13-2011, 02:18 PM
bigrigfixer's Avatar
bigrigfixer
bigrigfixer is offline
The Pacifier
Is it possible that you have the starter relay wires crossed? Is it a 3 or 4 terminal relay?
  #60
Old 11-13-2011, 06:59 PM
georget's Avatar
georget
georget is offline
not really sure, i know there is (2) large post, one on each side. then theirs (2) small post on the front. battery on one side, starter on the other, (sides). (front) when i plug the wires to it, the starter starts turning. i have been working on vehicles for about 17 years, (just a shade tree guy) i work on my things. But, this wiring thing has stumped me.
Quick Reply: Big Bronco FAQs
