Big Bronco FAQs - Page 5 - Ford Truck Enthusiasts Forums
Big Bronco FAQs
  #61
Old 11-14-2011, 11:28 AM
bigrigfixer's Avatar
bigrigfixer bigrigfixer is offline
The Pacifier
bigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputationbigrigfixer has a superb reputation
Your ignition switch might be shorting out if you have power to the relay with the key off.
  #62
Old 11-16-2011, 05:55 PM
georget georget is offline
georget is starting off with a positive reputation.
Let me start buy saying, i was wrong! thank you for the advice (Nixvet2000, and Bigrigfixer) after going to many bone yards, looking at the wiring on the few 77-79 Ford trucks my hard head finely seen what was wrong, like i was told! it was the neutral safty switch, it was unplugged. Not to mention "My Dumb A**" thought the 78 Bronco was to old for that device, i was wrong and i thank all who helped. i have found a REAL site for me and my 1978 BIG Bronco. (now i just need how to use the site......
  #63
Old 11-16-2011, 07:56 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
Recommend starting a new thread. This one should really be left as a location for links and general information as to where to find additional answers to full-size Bronco questions.
In the Big Bronco Forum, click the New Thread button and begin. Best of luck with the truck.
  #64
Old 11-26-2011, 12:29 AM
graflexmaster's Avatar
graflexmaster graflexmaster is offline
graflexmaster is starting off with a positive reputation.
great site.......
  #65
Old 02-15-2012, 07:56 PM
the truth's Avatar
the truth the truth is offline
the truth is starting off with a positive reputation.
Been looking at Bronco lately and just went to the FAQS page. Just want to let someone know the off-road link doesn't take you to the history and timeline of the Bronco's.
  #66
Old 02-16-2012, 12:28 AM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
For those of you interested in seeing the original options for the 78 and 79 bronco this site is really helpful:
Bronco Literature
Up on the top right corner should be a button that says BACK and it will take you to the home page. These are a list of the original brochures and advertisements, plus one that compares our beloved bronco vs. the Blazer.
  #67
Old 02-16-2012, 09:53 AM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is online now
AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.
I've seen that one about the Bronco vs. the Blazer before. I absolutely loved it.
  #68
Old 02-17-2012, 12:55 AM
That one was pretty cool, these brochures helped me figure out the options the original owner of my truck had put on. Which was most of the stuff.
  #69
Old 02-17-2012, 09:22 AM
the truth's Avatar
Quote:
Bronco Literature
Very cool, thanks!
  #70
Old 02-18-2012, 03:16 AM
Yup no problem.
  #71
Old 03-05-2012, 11:28 AM
tassmannn's Avatar
tassmannn tassmannn is offline
tassmannn is starting off with a positive reputation.
Smile Transmission shifter
I have a 1996 Bronco with 279000 miles on the original engine and tranny. It runs and drives fine, but curious as to how to possibly fix the shifter, and where to start. When you put it in gear, you can't really tell it is in gear since it does not "click" in. Is that inside the tranny or something to do with the shifter itself? Hope that makes sense.
Thanks!
  #72
Old 03-05-2012, 06:52 PM
Quote:
Thanks!
Welcome to FTE, the shifter clicking should be within the shifter housing inside the cab i think. It should be column right? In a floor shifter for a car if i remember correctly there are teeth and a spring loaded bar that clicks down into them. I am not fuller sure on how the column ones work but i would start by pulling apart the steering column and seeing if anything looks broken. If that doesn't help on the side of the transmission should be the linkage that moves back and forth and there might be an issue there.
In other words start with what you feel is easier, climbing under the truck and fiddling around is pretty easy.
  #73
Old 05-09-2012, 12:42 AM
So i got another Big Bronco helper. Ever want to know what CFM is best for your older bronco?
There is the equation, it can help you if you plan to buy a new carb.
  #74
Old 05-31-2012, 05:48 PM
dgabriele's Avatar
dgabriele dgabriele is offline
dgabriele is starting off with a positive reputation.
Quote:
Originally Posted by greystreak92 View Post
Ok, folks, the site is more or less up and running.
FAQ's
what's the site? I need to learn!
....oh there it is haha *i'm an idiot
  #75
Old 08-26-2012, 11:34 PM
Carstenseth Carstenseth is offline
Carstenseth is starting off with a positive reputation.
Bronco Literature
Thanks, that's pretty cool. It's hard finding info for those old FSBs.
Newbie needs help. Yes, I read faq GG150 New Member Introductions 3 04-08-2016 06:05 PM
FAQ (well, not really, but...) - Computer Wallpaper 2 for your pleasure girlwithatruck '80-'86 FAQs (Frequently Asked Questions) 14 06-15-2009 09:55 PM
tips and tricks FAQ for 335 series motors SoArkSI 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 15 12-06-2006 11:36 AM
1973-1979: FAQ's, Tips & Tricks, Projects, and FORUM INFORMATION, -PLEASE READ! Torque1st 1973 - 1979 F-100 & Larger F-Series Trucks 26 11-19-2006 10:01 AM
Tags
78, 87, big, bronco, external, faq, faqs, fire, ford, forum, fuel, problems, pump, running, sitting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
