Big Bronco FAQs - Page 2 - Ford Truck Enthusiasts Forums
Big Bronco FAQs
Old 01-26-2010, 03:06 PM
woodducked woodducked is offline
woodducked is starting off with a positive reputation.
Thanks
I really appreciate this site. Very good info, pretty clear, and clean. haven't even had to ask a question yet. " most already been answered. Thanks again woodducked
Old 03-12-2010, 02:55 PM
89fbronco 89fbronco is offline
89fbronco is starting off with a positive reputation.
I have an 89 bronco... that I have had many problems with. I have read the Haynes manual inside and out and have been all over the net trying to find a site like this one.Yes, I am allot smarter than I was a year ago, But I am also very grateful for stumbling across this site.
To whom the genius was who founded it...... thank you
Old 03-24-2010, 08:05 PM
diesel Bronco's Avatar
diesel Bronco diesel Bronco is offline
diesel Bronco is starting off with a positive reputation.
Big Bronco Project
Hey guys I have just aquired a 1983 Ford Bronco XLT and I have some big plans for this Truck. This truck has been worked on and had a 460 V-8 4 barrel carberator (edlebrock) engine put in it. The Truck has been sitting for about 3 years before I aquired it. Last thing that was done to it was the Truck was running fine, from what i have been told. Then the battery was not getting a decent charge so the alternator was changed and hasnt run since. I dont have a wiring diagram so if anyone has one, I could really use one cause i cant seem to make heads or tails of the wiring harness. I had a good battery just put in so it has juice but when i turn the ignition switch on with the key I get nothing not even lights. Also whoever installed this V-8 in the Bronco did not do a good job with the wiring harness. Any suggestion or help in the right direction would be very much appreciated. Also another note is later on down the road i am intending on selling the whole powertrain from this truck to convert it to a Cummins Diesel engine but for now i just wanna get the truck running so i can work out the kinks.
Old 03-26-2010, 01:05 PM
RaceDog RaceDog is offline
RaceDog is starting off with a positive reputation.
get yourself a oem meter and trace the power to were u loose it then u would have a better ideal whats going on?
Old 04-14-2010, 01:00 AM
bondobob65's Avatar
bondobob65 bondobob65 is offline
bondobob65 is starting off with a positive reputation.
On the Speed Density EFI Big Bronco's before you condemn a fuel pump check and make sure the fuel pump relay is operational and putting power to the pump the relay can hang up( it is on the drivers side inner fender panel near the aur cleaner box) and sometime tapping it will make the pump power up. You can confirm it by verifying voltage at the terminals or jumpering terminals to power the pump.
Old 04-29-2010, 02:55 PM
mattm31763 mattm31763 is offline
mattm31763 is starting off with a positive reputation.
82~83 Ford Bronco 4X4
I bought an 82 or 83 Bronco 4X4 Lariat a few years ago. It was not running when I bought it and had been sitting around 4 years. Owner had just parked it and bought another vehicle. Tried to get my uncle, a mechanic with 20+yrs experience, to help me get it running. He took one look at the variable venturi carbeurator and said he would help me once I got a new carb. I have been all over looking for a regular Motorcraft 4-barrel carb to convert to, or just a regular old 2-barrel. (He told me that the Motorcraft carbs were the easiest to rebuild.) Can anyone help? It is in great shape, but a little weathered. Just want to get her running again.
Thanks!
P.S. THIS is how I feel!
Old 04-29-2010, 06:27 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
Welcome to FTE and the Big Bronco Forum. We will do our best to get you the most accurate info we can dig up. I would suggest posting this question to the main part of the Big Bronco Forum as this thread deals with FAQ's and your questions is rather specific. Wouldn't hurt to try a search of the forum either. Was also unaware that Ford ever put the variable venturi carb in the Bronco. Everything I've ever seen has been Motorcraft, Holley, or Autolite.
Old 05-06-2010, 01:55 PM
Alvin in AZ's Avatar
Alvin in AZ Alvin in AZ is offline
Alvin in AZ is gaining momentum as a positive member of FTE.Alvin in AZ is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by WhlM1 View Post
...have never liked how FSB operates, or what they allow to go on.
I started out on newsgroups back in the early 90's so FSB is sort of a
free-speech zone like a newsgroup, just more on topic is all.
If you are a sensitive guy with a thin-skin then yeah, I can see where
you'd have trouble with FSB. LOL :) Is that the case?
I've got my own YouTube video, made just for me, by an FSB moderator,
of all people, I am so proud of this...
YouTube - Alvin in AZ You Are Wrong!
...please rate it high if you rate it at all, the guy went out of his way to
make it. LOL :)
Bossind1 is in Canada and is an instructor in an vocational like school. :)
Butthead in AZ
'91 Bronco Edweena Bauer, swapped icky E4OD for a ZF
Old 05-06-2010, 02:24 PM
Quote:
you'd have trouble with FSB. LOL Is that the case?
Gotta disagree with you here, friend. I have maintained a screen name (I simply don't contribute) over there for a long while now and there really is no good reason for the general inconsiderate attitude and rudeness displayed by a number of people over there. Just because someone is new to the Bronco or even trucks in general is absolutely no excuse for the demeaning and rude behavior routinely displayed particularly towards newbies on that site. When I started here several years ago, I had some of the dumbest questions now that I think back on it but no one here felt the need to tell me how stupid I was or that I should learn what I am talking about before I ask dumb questions. I've been invited to FSB. I've been invited to other Ford truck forums and sites. I stay here because there is none of that attitude tossed around whats more, if there is, it is dealt with as it should be. Asking a question is not an invitation to be berated for not knowing the answer because the ONLY "stupid question" is the one you DON'T ask.
Old 05-06-2010, 04:11 PM
Cool one Streaker. :)
Yeah FSB had to add a "Noobie No Flame Zone" forum! LOL :)
I disagree with the "stupid question" thing tho. :)
OK, I agreed back when I was in elementary school, but haven't since. ;)
Newsgroup stuff...
a) "stupid question" = hadn't bothered to read -anything- before asking
b) "one line questions" deserve one line answers
If it's both a "one liner" and a "stupid question, well heck, they're asking
for it! LOL :)
If the OP doesn't get defensive and throw a hissy-fit, the answer will get
posted for 'im, usually. BTDBoth things to an OP in the same thread many
times. LOL :) Even on FTE.
And a new one I've figured out on website forums here lately...
c) If they didn't bother to fill out the information about where they are,
they tend to be lazy and not worth helping. :/
Even if it's cryptic-crap like {our} location{s}, at least it's something. ;)
Butthead in AZ
Old 05-13-2010, 12:51 PM
beermonger beermonger is offline
beermonger is starting off with a positive reputation.
I thought we were here to share knowelege and maybe learn a few things about our trucks.
Old 05-13-2010, 12:58 PM
WhlM1's Avatar
WhlM1 WhlM1 is offline
WhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant futureWhlM1 has a brilliant future
Quote:
We are. The talk of FSB will stop after my post here, and any further discussion on it will simply be deleted. They can operate as they please, and so can we. Back to your regularly scheduled programming....
  #28
Old 05-13-2010, 01:08 PM
Keep on truckin'
  #29
Old 06-26-2010, 11:32 PM
Balian's Avatar
Balian Balian is offline
Balian is starting off with a positive reputation.
Oh oh, my wife is gonna hate that I found this site, my Bronco Fever is starting to riSE!!!!!!!
  #30
Old 08-11-2010, 10:31 PM
Mavericks9's Avatar
Mavericks9 Mavericks9 is offline
Mavericks9 is starting off with a positive reputation.
my fiance, already hate that i found this site. LOL. says ima be one of them guys that loves his truck more than his wife.
Newbie needs help. Yes, I read faq GG150 New Member Introductions 3 04-08-2016 05:05 PM
QUICK START GUIDE for new members plumber01 Texas Chapter 17 07-24-2013 10:34 PM
Need Help Understanding Texas Inspection/Emissions cougarman001 Texas Chapter 9 01-08-2012 11:15 AM
FAQ stuff...foreign to me. greystreak92 1978 - 1996 Big Bronco 26 03-09-2005 11:23 PM
Tags
78, 87, big, bronco, external, faq, faqs, fire, ford, forum, fuel, problems, pump, running, sitting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
