Front end shimmy - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Front end shimmy
Old 01-03-2009, 10:15 PM
jjaramz jjaramz is offline
jjaramz is starting off with a positive reputation.
Front end shimmy
Hi, what would cause a 02 F250 CC SB V10 6SPD manual to shimmy at 50-60MPH Front tires are new. All tie rods and ball joints are tight. Wheel bearings are properly adjusted. Drive line has new carrier bearing. Shimmy is in the front, makes the shifter jump badly and steering wheel jerk. Thanks, John
Old 01-04-2009, 06:07 PM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Thread moved to the SD forum.
What I'd do is take the wheels off the front, one at a time, and rotate them 45 degrees and then put them back on. As in, rotate the wheel in relation to the hub.
Sounds like that mysterious imbalance you can get even though the wheels are balanced.
2002 ford explorer brake noise sheaff44 Explorer, Sport Trac, Mountaineer & Aviator 4 01-19-2015 08:14 PM
Steering wheel/front end shimmy at speed MDSuperDuty Escape & Escape Hybrid 1 09-13-2014 09:21 PM
STILL HAVE INTERMITTENT SHIMMY NBT22555 1999 to 2016 Super Duty 10 06-04-2014 06:18 PM
99 steering wheel shimmy while braking DanK5 1997 - 2003 F150 5 08-04-2011 11:43 PM
04 F350 frontend shimmy! hilljackusmc 1999 to 2016 Super Duty 4 07-11-2006 09:08 PM
Tags
2004, 2006, 250, diesel, end, explorer, f150, f250, ford, front, shimmey, shimmy, steering, superduty, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
