Multifunction Switch for a 2003 F150 - Ford Truck Enthusiasts Forums
Old 01-03-2009, 06:08 PM
mcanik's Avatar
mcanik mcanik is offline
mcanik is starting off with a positive reputation.
Exclamation Multifunction Switch for a 2003 F150
Today I ordered a MFS from NAPA Auto. For a 2003 F150 7700. I verified that my switch has bit it due to the low beams failing. All that NAPA listed was the switches for the Lightning and the Harley Davidson. Both of those do not match the one I have. However, I had NAPA order one for a 2002 that looked identical to mine. My question is, does the switch for a 2002 fit for a 2003 model?
Old 01-04-2009, 07:44 AM
torkum's Avatar
torkum torkum is offline
torkum is gaining momentum as a positive member of FTE.
Same switch from 01-04 Heritage. Wonder what's different on the Lightning and Harley?
Old 01-04-2009, 02:57 PM
mcanik's Avatar
Not sure if the switch comes with the signal,dimmer,wiper control arm or not, but the arm is the difference in the way it looks. The Harley Davidson is chrome finish and straight. The Lightning is matte black with a different shaped angle on it. The 2002 listed switch looked identical to mine. I am almost sure they are all the same switch, Just the esthetics looked different.
Old 01-18-2009, 11:12 PM
mcanik's Avatar
The problem was not the switch, it was the plug that goes to the switch. Terminals 9 and 10 that control the low beam circuit got hot due to a poor connection. This in turn damaged the harness slightly. I tightened the female spades in the harness and re installed the switch. This will work for the time being but I am shopping for that part of the harness now. I am thinking I should relay the high and low beam circuit to reduce the load to the switch. Has anyone done this? Any ideas on some good quality relays?
Thanks.
Dan.
Old 01-19-2009, 03:27 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
Take a look at this. Bottom right corner of page 24. Good luck!
LMC Truck Parts - Page 24
Old 01-20-2009, 09:04 AM
ddrumman2004 ddrumman2004 is offline
ddrumman2004 is gaining momentum as a positive member of FTE.ddrumman2004 is gaining momentum as a positive member of FTE.
Same thing happened, sorta, to my son's 2000 XL truck. His turn signals quit working and I assumed it was the multiswitch.
Turned out to be wires pulling out of the big connector that connects the harness to the switch. We also assumed that this happened because he always...always tilts his steering wheel up and down when entering and exiting the truck. Ever since he bought it new!
Anyway, he made sure all the wires were in place and then used silicone RTV to "hold" the wires in place.
He tells me everything works just fine now but I still told him to hold on to that new switch!
Old 01-15-2013, 07:51 PM
FredLong FredLong is offline
FredLong is starting off with a positive reputation.
When I removed the multifunction switch wiring harness from the switch several wires came out and now I'm not sure which wire goes in which slot. Anybody have schematics or photo of which color wire goes where? Thanks! This is for a 2002 F150 Supercrew,,
2003 Harley Davidson F-150 bug deflector kstroman Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 1 04-30-2015 04:16 PM
03 Harley F150 Front End Swap White_Pride 1997 - 2003 F150 0 01-31-2015 11:24 PM
Aftermarket 05-07 Harley grille 88bronco351 1999 to 2016 Super Duty 3 12-17-2011 09:36 AM
2003 f150 harley davidson malverde Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 1 08-31-2011 01:36 PM
2002 Harley Davidson F-150 Top Speed??? Hodo03 Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 5 12-04-2005 06:59 PM
Tags
03, 150, 2002, 2003, 2004, connector, explorer, f150, ford, function, multi, multifunction, plug, switch, terminals
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
