Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 Performance Ford F-150's SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-03-2009, 05:49 PM
Raider50 Raider50 is offline
Raider50 is starting off with a positive reputation.
fx4 ring and pinion set up?
With my off road tires going much over about 110 is out the question, so on that note I figured a new ring and pinion setup to lower my gears would be in order. The truck is kinda heavy at some where around 6k and even with the roush on there it isnt just amazingly quick, its more real fast from 50-90ish. A mostly simple solution would be to get a new lower ratio right? I would like more quickness off the line but also a degree of drivability out on the highway. would a 4.10 be more apropraite or a 4.56 or somthing like that. Also who makes a really quality kit for a 4x4? Well thanks once again guys
__________________
Brute Force: If its not working, your not using enough.
If a little bits good, then a lot is better.
  #2 (permalink)
Old 01-03-2009, 07:45 PM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
Administrator
FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation FTE Ken has a superb reputation
What size are the tires? A 4.10 about 10% more engine revs per tire revolution, whereas the 4.56 is about 18% more. I'd take the original tire size, divide it by the new size and whichever it comes closest to go with it.
__________________
-Ken
If you need to get in touch with me email me at ftsservice at gmail dot com or via AOL IM: motorhavenken. Problems, questions, concerns.... please feel free to contact me.
- "So long and thanks for all the fish."
  #3 (permalink)
Old 01-04-2009, 11:04 AM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE.
What size tires are you running, also how big of lift are you looking to get?
__________________
2007 Lariat screw - White Sand Tri Coat - chrome package - Black leather captains chairs - sunroof - audiophile - 20" Mark LT wheels - Color Matched Door handles -
2005 XLT scab -
1995 xlt scab - 13 inches of lift - SAS
Needed: 2004-2008 OEM cat back for F-150 supercrew
  #4 (permalink)
Old 01-04-2009, 02:38 PM
the tires are in no way huge. I will need to look when i go out side, its not that they are that big it is that the a sort of low profile type offroad tire for the most part. The are on 20in by 12in wide rims and the truck only has a 2in leveling kit on it i know that. Because of that combo its hard to find a tire that fits and can go through snow mud and what not. The local tire shop just told me that they were not rated for more than about 110, no problem as of now because its still limted to 100. I was just thinking a new lower gear set up would be awesome paired with a troyer tune. With the wides on it i would think with the gears i could about break my neck on a launch. sorry for any confusion on having big meats on there, and thanks again guys
__________________
  #5 (permalink)
Old 01-05-2009, 12:43 AM
tylus's Avatar
tylus tylus is offline
2008 Ford Expedition
tylus is gaining momentum as a positive member of FTE.
if you want a hard breaking launch off the line, you'll need the 4.56 gears.
Your FX4 already has the 3.73 gears...and going to 4.10 will be a difference, but not worth the ~$2,000 for the front/rear axle install.
also, since you seem to have bigger tires than OEM, the 4.56 gears will help you regain your lost performance.
IMO, it's a 4.56 or nothing swap. That will make your truck a tire shredding low end monster when coupled with the Supercharger...If I ever have another $2k laying around, I'm slapping some 4.56 gears into there
__________________
  #6 (permalink)
Old 01-06-2009, 07:09 PM
the only thing i would like to know is how it would go at 70-80 on the highway with the 4.56's in it. My tires are only 32in so im not sure if it would be to low with the 4.56's on it.
__________________
  #7 (permalink)
Old 01-08-2009, 11:14 AM
tylus's Avatar
your tach would be about 2,200 to 2,400 for 70 mph with 4.56 gears and 32" tires
a 35" tire will put you about 2,000 rpm at 65-70 mph with 4.56 gears
so it's a best of both worlds IMO. the deep gears offset your bigger tires, and you get one heck of a performance boost down low. I currently run about 1750-1800 at 70 mph with my 3.73 set. So an extra 200-300 RPM will only lose me about 1 mpg
I can handle losing 1 mpg highway for the performance...not to mention, alot of the 6" lifted/35" tire guys report gaining city MPG after swapping in 4.56 gears
__________________
  #8 (permalink)
Old 01-08-2009, 07:54 PM
Ryan50hrl's Avatar
Quote:
Do you need a small crane to lift those suckers???
__________________
2005 XLT scab -
  #9 (permalink)
Old 01-09-2009, 10:26 PM
Quote:
nah, thats what my 18 inch cannons are for, liftin the tires
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
