Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
General Diesel Discussion SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 01-04-2009, 02:56 PM
paulo g paulo g is offline
paulo g is starting off with a positive reputation.
start with fuel .check hose,filters,a plastic bag in the tank,bad hose that dont leak but are so bad they let small amounts of air in, a crack filter housing or missing o-ring or crack.you can check fuel feed with a gauge on those engines before the main pump there is a vavle like th one used to take oil samples from cat engines. if all ok then take out the pump and get it checked.if all ok then go to the fuel injectors .they are hydrlicly operated with engine oil presure and are adjjustable.1 quarter to haft down from zero like the chevys.injectors could be checked for presure opening and quantity.could also the the timing.with time parts wear.for the not doing it when cold is becauce of the extra fuel added by the pump.cold start solinoid gives it a little more then drops off slowly. take it to deisel shop that rebuild big diesel engines.they sould have all the equipment to test and recondition.you will loss the truck for 2 days .cheaper if you take the parts off your self but go there leave the truck over night conect test equipment and start it up see what happens then remove the parts and get them tested one by one.this testing will cost between 200 - 300 dollars
  #17 (permalink)
Old 01-04-2009, 05:05 PM
starmilt starmilt is offline
starmilt is gaining momentum as a positive member of FTE. starmilt is gaining momentum as a positive member of FTE.
Yea paulo everything you mentioned has been gone over. I keep thinking air but it hasn't gotten any worse for several years and in the summer it doesnot do it at all.
Also it starts the same after sitting overnight or three months it is not actually a problem as far as running it but I would like it to be like it used to be.
__________________
absolutely no dodges.
to many fords to list.
one town car.
If it breaks because of my advice
you can keep both halves
  #18 (permalink)
Old 01-05-2009, 12:58 AM
orng1's Avatar
orng1 orng1 is offline
orng1 has a good reputation on FTE. orng1 has a good reputation on FTE.
Sounds like it could be an injector issue or maybe even a harness deal but then it would do it randomly. The injector can be bad and when it's cold it acts the worst until it warms up and starts to flow evenly. Could be... If you were close I'd tell you to bring it to my boss' shop and he'd diagnose it.
__________________
00 F250 5.4L K&N stock box folter, 257k miles.
01 F250 7.3L DP Tuner, Airaid intake, Magnaflow 4" turbo back, 88k miles. Bob
<img src="<a href=http://api.photoshop.com/home_e202e8e80efb4a1696c4980e2d094cf5/adobe-px-assets/c71a8ac8ad5f4072a1981a2a389f6f04 target=_blank>http://api.photoshop.com/home_e202e8...981a2a389f6f04</a>" width="450" height="150"/>
  #19 (permalink)
Old 01-05-2009, 10:52 AM
preppypyro's Avatar
preppypyro preppypyro is offline
Posting Legend
preppypyro is a splendid one to behold preppypyro is a splendid one to behold preppypyro is a splendid one to behold preppypyro is a splendid one to behold preppypyro is a splendid one to behold preppypyro is a splendid one to behold preppypyro is a splendid one to behold
If you fellas wanna see a white smoke startup, you should come check out my 444 cummins!
She smokes white for the first few minutes (or so, depending how cold it is) then clears right up! I was a little worried at first, but did some reading and research and found that was normal, whew!
__________________
$Sheldon$
2003 F-250 supercab shortbox 4x4 lariat
~Everythings legal man as long as ya dont get caught~
  #20 (permalink)
Old 01-05-2009, 07:25 PM
Yea I'm thinking I need a set of injectors but I think I'm going to wait and see what this economy does first. they supposedly tested them when it was inframed but with the miles on it new ones wouldnt hurt.
__________________
one town car.
  #21 (permalink)
Old 01-05-2009, 08:06 PM
chevenstein's Avatar
chevenstein chevenstein is offline
chevenstein is starting off with a positive reputation.
That's normal?!? We used to have an M123 army truck with the Cummins 300 V8 and it smoked so badly when cold that you could literally smoke screen a road to the point where people couldn't drive on it for a bit. Sorry for being off topic!
__________________
1990 F350 7.3IDI 4x4 ZF5
1962 F250 flatbed 4x4 Detroit Diesel 453, Clark 5spd OD
Used to have:
1989 F150 300I6 M5OD 2wd
1988 F250 7.3IDI 4x4 ZF5
1989 F350 7.3IDI 4x4 ZF5 (parted out)
  #22 (permalink)
Old 01-06-2009, 11:24 AM
Talking
Quote:
seen to muck action that truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
