Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007 and Newer Expedition and Navigator
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-02-2009, 09:19 PM
kkelly1121 kkelly1121 is offline
kkelly1121 is starting off with a positive reputation.
04 expedition 5.4L - engine noise
I own a 2004 expedition with a 5.4 liter engine. A knock has recently started which seems to come from the engine. The knock does not occur at all at idle or during normal driving regardless of torque or acceleration. It only occurs after pulling a long hill after cresting the hill and going to coast and only lasts 30 seconds or so. It appears worse when descending a long grade with the overdrive off and will continue constantly until accelerating or pushing overdrive button on then goes away. Have already tried to diagnose with chassis ear and have narrowed to upper engine or timing chain area. knock is loud very similar to a rod bearing knock - heavy metallic. oil pressure stays within specs with manual guage connected. Has anyone had a similar problem with any suggestions before I tear down to check cam phaser and timing components. Thanks for the input.
  #2 (permalink)
Old 01-03-2009, 06:06 PM
Z06PSI's Avatar
Z06PSI Z06PSI is offline
Z06PSI is starting off with a positive reputation.
Umm wrong section.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
