Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Early Broncos (1966 - 1977) SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-02-2009, 08:34 PM
xlrs xlrs is offline
xlrs is starting off with a positive reputation.
302 Heads
Hello All,
Can anyone tell me if 69 302 Bronco heads will fit on a 73 or 74 302?
Any help would be greatly appreciated.
Thanks
xlrs
__________________
Early 99 F250 Lariat 4x4. 7.3 Powerstroke. SWB, SRW.
87 F250 6.9 4X4
  #2 (permalink)
Old 01-02-2009, 09:12 PM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE.
They will physically bolt on. There may be a combustion chamber size difference between the early and late heads. I can't find my information about later model 302's after '71. But if the engine is stock, a small increase in compression will not hurt.
Jason
__________________
"Giggity" Missing your Prius? Check under my tires.
'08 Dodge 2500 MegaCab 4wd, 6.7 Cummins, 6 spd auto, DPF & EGR fell off
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
  #3 (permalink)
Old 01-02-2009, 11:33 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
Check your casting numbers against this:
Cylinder-Head Casting Numbers
Also note '73-'76 has a slightly taller deck to lower compression (to fight Nox before they figured out EGR).
Also, not sure when pedestal rockers came into play, but be careful if you change from one to the other. If the older ones have adjustable, you can probably use the pushrods from the older engine. Check this out before you run it.
Kelly hotrod - Ford Engines Page 2
These two links and other info are at the top of the SB forums.
  #4 (permalink)
Old 01-03-2009, 01:35 PM
RCrawler's Avatar
Rail rockers were introduced around '66. In the mid 70's, the studs were changed to the positive stop style. But neither should not be a factor here. As long as you match the rockers/ pushrods to the cyl head style, you will be fine.
Jason
__________________
  #5 (permalink)
Old 01-03-2009, 07:20 PM
Thanks for the help guys!
__________________
87 F250 6.9 4X4
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
