changing plugs on a 2000 crown vic 4.6ltr - Ford Truck Enthusiasts Forums
Old 01-02-2009, 07:40 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
<HR style="COLOR: #d1d1e1" SIZE=1 itxtvisited="1"> <!-- / icon and title --><!-- message --><TABLE width="100%" border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD vAlign=top itxtvisited="1"> This car has the Coil over plugs and I need to change the spark plugs.
Anyone done this is there anything I should know? Plugs are original and the car has 115K on it.
</TD></TR></TBODY></TABLE>
Old 01-03-2009, 01:47 AM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
The job is the same anyother COP mod motor. Be careful and take your time, cleanliness is very helpful as well. Remove the COPs, blow the holes out, remove the plugs. Install the new plugs, fill the new coil boots with dielectric grease and hook them back up.
I think I spend about 3 hours doing mine, torquing all of the bolts/screws back to spec. So far, I am pleased the Denso IR plugs I put in.
Old 01-03-2009, 05:50 AM
senix's Avatar
thanks for the info! hope to get it done today if weather permits.
Old 01-03-2009, 10:50 AM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Crown Vics are a breeze compared to the trucks. The fuel rails shouldn't even be in the way on the car.
Old 01-03-2009, 03:04 PM
senix's Avatar
Well, I got her done. No problems at all, boots came right off and very little dirt as I have steam cleaned the motor a few times. Plugs were a little tight but not too much that I was going to break the plugs. So now we are good for another 100,000.
65 350 ??? gangstakr 1961 - 1966 F-100 & Larger F-Series Trucks 5 03-06-2010 02:50 PM
still need help bad!! ford f350 tranny donny3369 1999 - 2003 7.3L Power Stroke Diesel 4 12-03-2008 08:13 PM
2000 f350 clutch master cylider and slave mrbs66 1999 to 2016 Super Duty 2 11-21-2008 08:11 AM
Flat Head Knock HOILERAUTO Flathead V8 & Flathead 6 9 10-15-2008 11:13 AM
VIN Fraud?! J1MMY 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 28 10-01-2008 03:42 PM
Tags
2000, 2003, 46, careful, change, changing, corwn, crown, ford, location, plugs, replace, spark, vic, victoria
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
