5 beeps 5 times - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
5 beeps 5 times
Old 01-02-2009, 06:13 PM
EaTmYtAiLpIpEs's Avatar
EaTmYtAiLpIpEs EaTmYtAiLpIpEs is offline
EaTmYtAiLpIpEs is starting off with a positive reputation.
5 beeps 5 times
it seems like recently almost everytime I start my truck it beeps 5 beeps 5 times. so it beeps 25 times. what could this be and how do i get rid of it. I wear my seatbelt so it is not that. there has to be a relay or something to stop the dam thing from doing it.
Old 01-02-2009, 06:51 PM
99f350sd 99f350sd is online now
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
My bros e 350 2003 does the same thing has him pulling his hair out..
Old 01-02-2009, 06:56 PM
ya it is driving me crazy it is annoying as all hell!!!!
Old 01-02-2009, 07:05 PM
Fordfanatic4life Fordfanatic4life is offline
Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.
disconnect the battery for a few mins and reconnect it..
see if it resets whateva alarm is tripped..doubtful but worth the hassle of losing ur radio presets i guess.
Old 01-02-2009, 07:07 PM
scraprat's Avatar
scraprat scraprat is online now
scraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud ofscraprat has much to be proud of
My '99' does this it will keep cycling the beep every 20 minutes +/-, there was a thread on here year or 2 ago about what it was and how to fix it. Keep the music up and if you have passenger and ask what's that beeping play it off that you don't hear anything it will drive them crazy.
Old 01-02-2009, 07:12 PM
dew the thunder's Avatar
dew the thunder dew the thunder is offline
dew the thunder is gaining momentum as a positive member of FTE.
My friend's F150 was making beeping noises but had other problems as well. Radio not working properly and windows not working properly... ended up replacing the GEM module. All's fine now I guess.
Old 01-02-2009, 07:28 PM
scraprat's Avatar
I found my thread from years ago.
http://www.ford-trucks.com/forums/16...tone-code.html
But someone posted what the problem was and the fix. Never fixed mine, just learn to ignore the noise. That truck has 240,000 miles on it and nothing ever went wrong with it.
Old 01-02-2009, 08:48 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Wow..
The 5 x 5 beep is the backup alarm for the airbag system. This is in the owner's manual.
Replace the airbag warning lite in the cluster and the beeping will go away. Now, with a primary warning indicator that works, you can count the flashes to get a two-digit lamp Fault Code (LFC) that will guide you towards diagnosing the fault in the airbag system.
Steve
Old 01-03-2009, 09:56 AM
Yougotthehit Yougotthehit is offline
Yougotthehit is starting off with a positive reputation.
Quote:
Originally Posted by projectSHO89 View Post
Wow..
Steve
What he said! I had this issue when I pulled the airbag light because it annoyed me. When I did that the beeping started. Put it back in and it went away. Found about it was a backup.
Old 01-04-2009, 05:36 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Wow..
Rep points for that
Old 06-16-2010, 12:53 PM
RLF350 RLF350 is offline
RLF350 is starting off with a positive reputation.
Fixed the 5 beep sequence
I too had about 100,000 on my 2002 F-350 when every time I started it there was a 5-beep chime sequence for 5 sets (or 25 beeps). Took it to a mechanic and they couldn't find anything wrong.
I found this blog while searching for a solution, and it is so obvious I can't believe I didn't notice it before. You guys were all so close SRS, ABS, but here's the fix...
Notice on your dashboard there is a passenger-side airbag on/off switch. Now think about the amber indicator lamp on the instrument panel (lower right-hand corner) with a guy sitting with an airbag inflated? Remember how annoying it was when that light was on all the time -- its to remind you to disable the airbag if you have a small child or infant sitting in the front seat. Cars don't have it, because they have a back seat -- of course your truck probably does too, but remember FORD builds one dash cluster which also is in the standard cab!
OK -- now I bet along about the time you heard those beeps, that little light was not on anymore? AH HA! Yes -- you will also get the same beeps if you mess with your Check Engine light.
Remove the radio (get a Ford radio removal tool at WalMart) then carefully remove the dash cowling - no tools use your fingers as they are all snap connectors, Remove the instrument cluster with a 9/32 socket, disconnect the 3 wire harnesses plugged in back. flip the cluster upside down, you remove the lights from the backside, DON'T try to peel up the instrumentation graphics.
Notice the location of the airbag lamp, take a 9/32 socket and gently turn the lamp holder a 1/8 turn counter-clockwise, and the holder should pop-out. Easier said then done, you will notice that it is the hardest lamp to get to.
Get a replacement bulb at any auto parts store (the bulb pulls out of the holder, you do not need to buy the entire unit from Ford). replace, reinstall the panel, dash and radio and start your truck. No beeps!!!
Last edited by RLF350; 06-16-2010 at 12:58 PM. Reason: Make sure everyone knows to remove the bulb from the back.
Old 06-16-2010, 01:07 PM
TennesseeMustangPerf's Avatar
TennesseeMustangPerf TennesseeMustangPerf is offline
TennesseeMustangPerf has a good reputation on FTE.TennesseeMustangPerf has a good reputation on FTE.
Good deal. BTW, the SRS and ABS systems are different things. SRS is Safety Restraint System i.e. airbags, the ABS is Anti-Lock Brake System.
Old 11-02-2011, 12:16 PM
dboftx dboftx is offline
dboftx is starting off with a positive reputation.
Easy fix for 5-beep issue
First of all, a huge THANK YOU to everyone in here and in other forums for all the info on the cause of the "5 beeps 5 times" issue. The problem in my 2000 Expedition was a burnt out airbag warning light, as explained earlier (probably burnt out because I ignored it for so long). The instructions in this thread are great for replacing the bulb (BTW, mine was a tiny little bulb, type 74 I think).
Beyond that, the root cause of the airbag warning was incredibly easy to fix, so I thought I'd post it here in case others have the same issue. From searching many online forums, I learned that my airbag fault code, 37, is very common. It's a warning for a passenger seat airbag. Even if you don't have the airbag in the seat, you still have a connector for it under the passenger seat, which plugs into some type of termination plug. This can easily get kicked or disturbed from stuff being pushed under the seat. To fix the error, simply unplug and reseat the connector. Works like a charm!
The beeping was driving me insane, SO glad to have it fixed!
Old 11-10-2014, 10:19 AM
Sharlee Kuchynka Sharlee Kuchynka is offline
Sharlee Kuchynka is starting off with a positive reputation.
Quote:
Have u checked the passenger air bag light? Ours is beeping the same way, think its the airbag bulb..
Old 11-10-2014, 11:14 AM
Quote:
You need to read this WHOLE thread. The answer is already here.
The beeping is a backup for the fault light in the cluster. It means that you have to fix that first, then that bulb can flash out a code that actually tells you what's wrong. The PAD bulb is one of more than a dozen possibilities.
Beeping noise 87&97Aerostrar Aerostar 21 02-17-2017 10:06 AM
Source/cause of 'random' beep/chime in cab dh_meyer 2009 - 2014 F150 8 07-15-2016 09:00 AM
Loud beeping coming from under Dash.. JessieDM 1987 - 1996 F150 & Larger F-Series Trucks 12 10-17-2015 02:50 PM
Back up sensors gone wild. "Phatman" Excursion - King of SUVs 7 07-25-2015 07:41 PM
Truck beeps at me 25 times shadyEats Ranger & B-Series 13 06-15-2015 03:00 PM
Tags
150, 200, 2000, 25, 350, 99, airbag, beep, beeping, beeps, explorer, f150, ford, series, times, warning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
