Sounds like the spring that keeps the interior door handle in a locked position has broken. It's a little piece of steel that is pressed in. If you remove the guts of the door and remove the latch and linkage you will see it, it is on the
part where the interior handle is. You can get the part, I have seen them listed in the catalogs. It's a simple fix, a pair of needle nose pliers to remove the old one, and you just press the new one in.
