Wiring Question for y'all electrical types
Old 01-02-2009, 01:59 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
Red face Wiring Question for y'all electrical types
I did some mudding today...and noticed something a few minutes ago during the de-mudding process.
While playing around, the truck went into a dip and I heard a huge bang. Assumed it was the hitch hitting the ground and thought nothing of it.
I found my 4-pin hanging loose from the bumper packed full of mud. The 7-pin was packed full of red clay. And to top it all off, the 1/8" metal mounting bracket is bent and a weld is popped.
I cleaned out the mud/clay from both connectors as best as possible, but they both have some water in there that I cannot get out.
Is this going to be a problem? Lights and everything still work, so no short has appeared yet. I'm just wondering about corrosion and/or any other little gremlin that might appear. Pretty sure it's okay, but I try to avoid electrical stuff, so am pretty clueless about it.
Old 01-02-2009, 05:35 AM
shorebird's Avatar
shorebird
shorebird is offline
You may want to use compressed air to dry out the connections. Then give them a coating of WD-40. After the WD is dry some dielectric grease will prevent corrosion.
Old 01-02-2009, 06:22 AM
rocdril's Avatar
rocdril
rocdril is offline
Ditto, just make sure you didnt rip any insulation off the wires going into the connectors or rip any wires out (even a little) if they move around over time they could short.
Old 01-02-2009, 08:22 AM
96sherm's Avatar
96sherm
96sherm is offline
a shop vac should get the remaining water out. now would be a good time to relocate the harnesses to a safer location. i liked when they had them above the bumper step, built into the bumper itself. not too much could get at it there.
Old 01-02-2009, 10:10 AM
MisterDave2's Avatar
MisterDave2
MisterDave2 is offline
And if you need to, spray up the contacts on both sides with contact cleaner and plug in and out a few times, then shop vac. I second the relocate idea. Happy wiring!
Old 01-02-2009, 04:54 PM
spatts's Avatar
spatts
spatts is offline
Grainger sells an electrical spray that displaces water and cleans/protects at the same time without damaging plastic components , and is non-conductive.
Skinsfan6
Offroad & 4x4
01-25-2007 03:56 PM
90ebbronc
General Automotive Discussion
17
01-21-2004 11:54 PM
iridiumred
1999 to 2016 Super Duty
09-17-2003 03:20 PM
iridiumred
Modular V10 (6.8l)
09-15-2003 01:09 PM
jetjock16
09-09-2003 12:43 PM
Quick Reply: Wiring Question for y'all electrical types
