Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > The 2009 F150
The 2009 F150 Discuss the new 2009 Ford F150
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-02-2009, 12:06 AM
fireball 440's Avatar
fireball 440 fireball 440 is offline
fireball 440 is starting off with a positive reputation.
09 f-150 suspension
I read the rear leaf springs are 6" longer. I can't find any info on the front suspension. Is the front suspension the same as the 04-08?
__________________
The average human body contains enough fat to make 7 bars of soap.
  #2 (permalink)
Old 01-02-2009, 04:09 AM
fonefiddy fonefiddy is offline
fonefiddy is gaining momentum as a positive member of FTE.
It's been tweaked a little also. Plenty of info on Fords site.
__________________
93 F One Fiddy- 5.0/AOD/3.55 230K OEM
93 F Two Fiddy Scab- 7.3/ZF5/3.55/Sidewinder II,94 Turbo pump,G Inj's, Velvet Ride, Ride Rite Rear, Turbo Bumper, Alcoa's
85 F Two Fiddy-6.9/C6/3.54/ Holley Red, Racor, Soup Bowl,AutoJet 3",Ride Rite Rear
http://www.ford-trucks.com/user_gall...149391.520.390
  #3 (permalink)
Old 01-02-2009, 12:21 PM
Power Kid Power Kid is offline
Power Kid is starting off with a positive reputation.
Lower control arm now stamped steel vs cast aluminum. Funny Mike Rowe used to mock GMs for that?
  #4 (permalink)
Old 01-02-2009, 04:47 PM
Quote:
Is the front the same as in the same level kits will work?
__________________
  #5 (permalink)
Old 01-02-2009, 05:06 PM
I don't know. I suspect they are the same dimensions
  #6 (permalink)
Old 01-02-2009, 06:28 PM
tseekins's Avatar
tseekins tseekins is offline
tseekins is gaining momentum as a positive member of FTE. tseekins is gaining momentum as a positive member of FTE.
Anyone know the correct or logical reason for that change? Is it weaker, lighter or just cheaper to build?
Tim
__________________
SCPO United States Coast Guard Retired
Country Boy from Stockton Springs, Maine
'04 Expedition XLT 4x2
'99 Taurus Wagon SE 24V
'88 F-150 4x4 XLT Lariat 5.8L 5Spd
  #7 (permalink)
Old 01-02-2009, 06:38 PM
Bsimmer3000's Avatar
Bsimmer3000 Bsimmer3000 is offline
Bsimmer3000 is starting off with a positive reputation.
Quote:
Tim
I guess it's a strength and weight saving issue. The cost is prob very minimal. Alloy is great but has it's flaws. It is soft, Is heavy in certain circumstances (example alloy wheels compared to steals). Also i guess they were just cast alloy and not billet alloy so they prob not as strong as the steal either. I had some Cast alloy Mountain bike components and they would always crack under hard use. Ended up changing to CNC machined billet. No breaks so far.
  #8 (permalink)
Old 01-02-2009, 07:47 PM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE.
I would guess its cheaper to build.....cast aluminum is much more expensive to make than stamped steel.....
those aluminum ones are very light, i'd have a hard time believing that the steel ones are lighter....
__________________
2007 Lariat screw - White Sand Tri Coat - chrome package - Black leather captains chairs - sunroof - audiophile - 20" Mark LT wheels - Color Matched Door handles -
2005 XLT scab -
1995 xlt scab - 13 inches of lift - SAS
Needed: 2004-2008 OEM cat back for F-150 supercrew
  #9 (permalink)
Old 01-03-2009, 09:58 AM
WhëëlMå1's Avatar
WhëëlMå1 WhëëlMå1 is offline
WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of WhëëlMå1 has much to be proud of
You can certainly create a steel stamping to be stronger than an aluminum casting. I am sure that Ford found a way to reduce cost by going to the stamping, but also increase the rigidity of the product. While Ford is looking to reduce costs wherever possible, I do not think they will compromise on quality.... of the product that has kept them in front for all these years.
__________________
Rich
04-08 F150/Big Bronco Moderator
FTE Guidelines
Support FTE!
Support American Manufacturing!
"Made in the USA"
  #10 (permalink)
Old 01-03-2009, 10:54 AM
tseekins's Avatar
Quote:
I certainly hope your right. It makes us look pretty silly when we advertise the size and strenght of a suspension component vs the competition and then adopt thier method in a later model.
If this is actually better then my hat is off to FMC for doing whatever it takes to make the F-150 better.
Tim
__________________
  #11 (permalink)
Old 01-03-2009, 03:30 PM
Ryan50hrl's Avatar
I have a hard time believing its for strength, as the raptor has extended aluminum ones.....if they needed more strength in a stock vehicle, they surly would not have made a longer (more leverage=more stress) one out of aluminum on a truck thats expected to take more punishment than a stock truck...
__________________
2005 XLT scab -
  #12 (permalink)
Old 01-04-2009, 07:58 AM
rc6869's Avatar
rc6869 rc6869 is offline
2009 Ford F-150
rc6869 is starting off with a positive reputation.
Quote:
I saw on fordf150.net that the leveling kits for the 04 - 08 are the same as the 09. Ford F150 Photos - 2004-'08 & 2009 F150 2.5" Leveling Kit Billet Strut Extension RIZE - Powered by PhotoPost
  #13 (permalink)
Old 01-04-2009, 09:55 AM
Quote:
Alloy is strong when testing weight for weight but no where near as strong as steal for doing the same job. The extra weight that is gained from the small arms on the 09's is marginal but if they were steal on the raptor it would be a massive weight increase over alloy. There is no alloy that is stronger than steal and thats why most car frames and roll cages and suspension parts in cars/trucks are made from steal.
  #14 (permalink)
Old 01-04-2009, 10:18 AM
Ryan50hrl's Avatar
Steel and aluminum have almost equal strength, pound for pound......however since aluminum is a lighter material, roll cages would have to be made out of like 3 inch tubing, and since most people can't weld aluminum...thats why roll cages aren't made out of it....also they have a lower threshold for strength loss after bending.....still...ford isn't going to put a weaker a-arm on the raptor than on the stock models.....i still maintain they're equally as strong
__________________
2005 XLT scab -
  #15 (permalink)
Old 01-04-2009, 04:22 PM
Roll cages with never be made from Alloy. It just cant take damage well. What would be the point in making an alloy roll cage the same weight as a steal one so that they could get the strength of a steel one! There would be No weight saving and no strength gain. This goes for anything alloy. It's great for some jobs but on components that take a beating and need to be tuff it's not really the best material of choice. There's no doubting that steal is a lot stronger than alloy but alloy does look cool when polished lol
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
