Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Early Broncos (1966 - 1977) SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-01-2009, 11:52 PM
v8xploder's Avatar
v8xploder v8xploder is offline
v8xploder is starting off with a positive reputation.
3g alternator?
What is a 3g alternator? Pros/cons? I noticed that BC Broncos has an adapter to run one of these with an EFI harness. I was just going to use the alt out of the 88 I got the harness from...
__________________
Cody
69 Bronco, 351W, Edelbrock performer, Holley 670 T/A 35'S 5.5'' Wildhorses lift, Locker rear, F-100 power steering and a slight rear main leak
92 Bronco Eddie Bauer, 351w, 31x10.50 No rust!!!
  #2 (permalink)
Old 01-02-2009, 01:48 AM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE.
The 3G is a late model, internally regulated, high output alternator.
I have one on mine and it works great.
Jason
__________________
"Giggity" Missing your Prius? Check under my tires.
'08 Dodge 2500 MegaCab 4wd, 6.7 Cummins, 6 spd auto, DPF & EGR fell off
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
  #3 (permalink)
Old 01-02-2009, 06:27 AM
v8xploder's Avatar
late model as in modular ford motors? (4.6.5.4?) or even 5.0 and 351 EFI?
__________________
Cody
  #4 (permalink)
Old 01-02-2009, 12:01 PM
RCrawler's Avatar
Here is a list of vehicles that have the 3G alternator:
93-96 Tarus 3.0 V-6 (non SHO)
94-96 Mustang 3.8 V-6
94-95 Mustang 5.0
94-96 Thunderbird 3.8 V-6 (non SC)
95-96 Windstar 3.0 V-6 (most are 3.8's)
93-96 E/F series Trucks/Vans 4.9 L6*
96 Sable 3.0 V-6
94-96 Cougar 3.8 V-6
Jason
__________________
  #5 (permalink)
Old 01-02-2009, 05:45 PM
Cheshire Cat's Avatar
Cheshire Cat Cheshire Cat is offline
Cheshire Cat is starting off with a positive reputation.
Jason, do any of the vehicles listed run a v-groove belt?
__________________
1969 EB, 302, 3 speed on the floor, f150 springs up front, 2in lift leafs rear, font disc's, working on power steering and EFI. 1966 Mustang 302, c4. Both under construction..
  #6 (permalink)
Old 01-02-2009, 08:57 PM
RCrawler's Avatar
Quote:
No. All of them are serpentine belt applications. However, a standard Ford alternator pulley will fit on them. As I mentioned in the other post, I ran a single groove pulley for a while but had some belt slippage issues. I used a smog pump application dual groove alternator pulley for a 77 Bronco. I had to machine the back side of it (about .050, as I recall) for clearance to the alternator housing.
Jason
__________________
  #7 (permalink)
Old 01-03-2009, 03:22 PM
thanks, that's what i thought, but i figured i would ask.
__________________
  #8 (permalink)
Old 01-03-2009, 09:50 PM
mauicruza mauicruza is offline
mauicruza is starting off with a positive reputation.
Jason
Jason, did you ever figure out a way to adapt a voltmeter in the stock speedo head in place of the amp gage? I remember you kicking around the idea a couple of years ago.
  #9 (permalink)
Old 01-04-2009, 02:45 AM
RCrawler's Avatar
Quote:
I got as far as taking a stock cluster apart and trying to match a gauge with the right sweep and with similar dimensions as the amp gauge. I am currently in the middle of remodeling my house. So MY projects have been put on hold .
Jason
__________________
  #10 (permalink)
Old 01-04-2009, 09:29 AM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
1975StroppeBaja has a good reputation on FTE. 1975StroppeBaja has a good reputation on FTE. 1975StroppeBaja has a good reputation on FTE.
There was an article about this in issue #8 of Bronco Driver... I'll try & dig it up sometime soon
edit -- If I recall, I think the article involved installing an aftermarket voltmeter in place of the stock ammeter, in the EB gauge cluster. Not, modifying the existing ammeter to be a voltmeter. If there's still some interest, I'll try & post up the article....
Here's a related thread on cb.com...
http://www.classicbroncos.com/forums...eter+voltmeter
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
