Which HID kit?
Old 01-12-2009, 06:40 AM
willie923's Avatar
willie923
willie923 is offline
Oh I forgot to mention, I'm sure that if you look at all thoose HID conversion kits out there they are not D.O.T. approved.I did find online aux driving lights that are D.O.T. approved which are very cool looking
Old 01-12-2009, 08:21 AM
mattd17's Avatar
mattd17
mattd17 is offline
Originally Posted by willie923
The upgrade harness has a heavier gauge wire vers a thin gauge factory wire.Heavier gauge wire means less voltage loss which leads to brighter bulbs.Though the more voltage will cut the life of your bulb but at least the bulb is meant to be used in that light housing.
the upgraded harnesses also use a relay bulit into them, to allow the full 14 volts to reach the lamps, rather than the 12 volts that the stock wires allow. and, they also give you the ability to keep the low beam filament on while the high beam is on.
the 2 features added together really do make quite a difference.
chrisbrady498
06-13-2014 06:04 PM
Skylaneman
1999 to 2016 Super Duty
12-08-2012 12:17 PM
Brad2296
Electrical Systems/Wiring
19
01-06-2011 05:47 AM
JohnnyAirtime
10-12-2009 10:49 AM
whitebus61
09-12-2009 03:50 PM
Quick Reply: Which HID kit?
