Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 01-01-2009, 02:41 PM
John7894's Avatar
John7894 John7894 is offline
John7894 is starting off with a positive reputation.
2003 no cruise control, no A/C either.
Anybody know where to start looking for the following problems?
The cruise doesn't work at all, no check engine lights or anything to maybe indicate a clock spring problem.
The A/C has a mind of it's own. Sometimes it'll work and sometimes it doesn't.
Are there any known problems regarding these problems? Just looking for a place to start looking.
__________________
John
2008 F350, 6.4, Crew Cab, King Ranch, 4WD, SRW.
2001 F250, 7.3, Crew Cab, Lariat, 2WD. 329,000 miles and counting!! Soon to be sold...
  #2 (permalink)
Old 01-02-2009, 01:47 AM
pilot10 pilot10 is offline
pilot10 is starting off with a positive reputation.
A/C - no clue- but kinda sounds like an intermittent short.
From my Chilton's manual:
Cruise-
check fuses,
check to see if your brake switch is working properly(are you're brake light working properly- either stuck on or not coming on)
Visually inspect the control cable between cruise control motor and throttle linkage for free movement- replace if necessary.
I took a look at the wiring diagram but don't see a common point between the two systems- However it's late and the fine print is starting to make my head spin so I would review the diagrams yourself.
tim
__________________
06 F150 King Ranch
  #3 (permalink)
Old 01-02-2009, 10:28 AM
John7894's Avatar
Thanks for the help. This is my sister's car so it's all new to me. I'll have to get under the hood and take a look.
__________________
John
  #4 (permalink)
Old 01-03-2009, 01:41 PM
ericsmith32 ericsmith32 is offline
ericsmith32 is gaining momentum as a positive member of FTE.
Both run off of vacuum. Is it idling funny? Check all the vacuum hoses.. as fun as that may be.
__________________
04 Escape XLT Sport 3.0L
06 Ranger XL 2.3L
The best never rest.. Built Ford Tough
  #5 (permalink)
Old 02-06-2009, 09:36 AM
ncranchero's Avatar
ncranchero ncranchero is online now
ncranchero is gaining momentum as a positive member of FTE.
Didn't see a cruise recall for this model/year.
A possibility??????????
TSB
06-9-3 PCM FAILURE - ELECTRICAL ACCESSORIES INTERMITTENT - INOPERATIVE
Some vehicles may exhibit a powertrain control module (PCM) concern that results in no crank, no start, or malfunction indicator lamp (MIL) with one or more diagnostic trouble codes (DTCs) present. There may also be intermittent or inoperative power windows, door locks, keyless entry system, lighting, speed control, radio, instrument cluster warning lamps (possibly dimly illuminated instead of being off), or other electrical accessories. The concern is typically more noticeable in wet and/or cold weather conditions.
__________________
________________________________
"Information is valued and appreciated...Attitude is not!"
Steve,
'98 F150 Super Cab 4x4, '99 Mustang 35th,
'02 Sport Trac 4x4, '01 Sport Trac Job 2 donor vehicle
'08 E250 Super Duty, No more Ranchero
  #6 (permalink)
Old 06-30-2009, 07:39 AM
Joe04F150 Joe04F150 is offline
Joe04F150 is starting off with a positive reputation.
Did you find a problem with the cruise, a lady friend here at work is having the same problem. The manual doesn't list a fuse for speed control...is there a fuse somewhere?
__________________
2004 F150 Supercrew 5.4 4x4
1999 Lincoln Navigator(Wife's)
2000 Camaro SS
2002 Yamaha R1
http://www.ford-trucks.com/user_gall...id=179974&.jpg
  #7 (permalink)
Old 06-30-2009, 10:00 PM
Trublufords Trublufords is offline
Trublufords is starting off with a positive reputation.
Check to see if switch at brake pedal is out of adjustment,I ussally put a paper clip in connecter to see if this is the problem,test drive to see if CC works----NOT the Brake light switch--CC deactivation switch.CC is NOT Vac ,it is electronic.Ac could be faulty Low pressure switch or weak field coil on Ac clutch OR a very wide air gap on ac clutch(works when outside and engine temp is low and as temps increase and ac goes to cycle off and back on not enough magnetism to engage clutch again).Vacuum??? I don't think so, electronic activated doors(temp blend)I am pretty sure. LOL Blue
  #8 (permalink)
Old 07-01-2009, 09:39 AM
wptski wptski is online now
wptski is starting off with a positive reputation.
Quote:
I can't even find the steering wheel cruise control switches in a '09 wiring diagrams either!! Very odd....
__________________
Bill
09 Ford Escape Limited, 3.0L, 4WD, AdvanceTrac
  #9 (permalink)
Old 07-01-2009, 07:33 PM
I found the fuse on the driver side kick panel #5 5amp, it was fine, looked under the hood and found both cables were off the clips prior to the bracket. put the throttle one back on, couldnt get the cruise one back on the insert, I'll try again tomorrow when I have some tools. She said the light comes on but nothing happens... ?
__________________
2000 Camaro SS
2002 Yamaha R1
  #10 (permalink)
Old 07-01-2009, 08:43 PM
Did you look at the push button type cruise deactivation switch touching the brake pedal under dash?Found about 10 escapes(no cruise complaints) and every one was out of adjustment with no cruise. Jump wire and then test drive.If cables were off clips prior to bracket and that was you problem don't you think the throttle cable would not work also?Unplug wire connecter at speed control servo and with key on make sure two wires are powered up(test light) key off one wire powered up. If key is on and only one wire is powered up jumper two wire conecter under dash at deactivation switch and see if you now have two wires powered up- yes -then test drive. Escapes do not have the deactivation switch out on the master cylinder like the ones on the Fords that were recalled for poss fires.I prob did at least 300 of those recalls. LOL Blue
  #11 (permalink)
Old 07-01-2009, 08:52 PM
just to clarify the cables were just off the clips that route them to the bracket, not off the bracket itself. I'll check the switch and run the tests you suggested too. Thanks for the tips!
__________________
2000 Camaro SS
2002 Yamaha R1
  #12 (permalink)
Old 07-02-2009, 01:35 PM
here is a pic of the clip I'm trying to describe....where the heck does it go???? Is there a bracket missing or something? This is under the black cover on the passengar side about 8-10 inches from the bracket where the cables go.
__________________
2000 Camaro SS
2002 Yamaha R1
  #13 (permalink)
Old 07-02-2009, 01:40 PM
And unlless I pound it in it doesnt go in that insert willingly...and it has stops on the cable where the clip is so it can't got too far from there...? I also checked the switch on the pedal, turned it and popped it out and it seemed ok...put it back in and made sure it was touching the pedal. I told her to try it again. I have limited tools and time here at work so I check on her afternoon 15 min break.
__________________
2000 Camaro SS
2002 Yamaha R1
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
