Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
Early Broncos (1966 - 1977) SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-31-2008, 06:13 PM
david00f150 david00f150 is offline
david00f150 is starting off with a positive reputation.
Engine Size?
Will a 400 ci motor fit in an early bronco? It is the same block as the 351M. I ran across a pretty good deal on one and was debating on using it for my next project.
__________________
*Newly Aquired* 1977 Bronco
1987 5.0L V8 F150 Custom
  #2 (permalink)
Old 01-01-2009, 12:03 AM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE.
It can be done. There was a guy that used to hang around here that had one in his. You would need to change the bellhousing and modify the engine mounting a bit.
Jason
__________________
"Giggity" Missing your Prius? Check under my tires.
'08 Dodge 2500 MegaCab 4wd, 6.7 Cummins, 6 spd auto, DPF & EGR fell off
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
