Question about Auto meter water temp gauge.
12-31-2008, 02:22 PM
Master of Strokes
Hello all,
I am installing a F 650 lower dash pannel right now and I am installing a water temp gauge but when I put the temp sender into the aux port on the sid of the water pump the fitting leaks no mater how hard I tighten it.
Any help is greatly appreciated,
Thanks
Nick
12-31-2008, 02:26 PM
on
Is it leaking from around the threads or from the sending unit wire? Did you use thread sealant on the threads before installing it?
12-31-2008, 02:29 PM
Master of Strokes
Yes I used thread sealant around the threads and its leaking from around the sending unit wire
12-31-2008, 02:30 PM
mechanical or electric
if mechanical sounds like you didn't use the adapter
12-31-2008, 02:35 PM
Master of Strokes
12-31-2008, 02:36 PM
that's a mechanical guage did you use the adapter
12-31-2008, 02:38 PM
Master of Strokes
Quote:
Originally Posted by
rbaker6336
that's a mechanical gauge did you use the adapter
What adaptor are you referring to?
12-31-2008, 02:41 PM
there should be an adapter fitting that the guage wire screws into and screws into water port ,that is what makes the seal
Ultra Lite Coolant Temperature 120-240 Degrees, 4333
Includes 12 ft. tubing.
Includes 1/2"" NPT adapter/fitting
12-31-2008, 02:47 PM
on
Yes you should have a mounting nut(adapter) and a sealing nut the mounting nut goes into the port and the sealing nut screws into the mounting nut.
12-31-2008, 02:59 PM
Master of Strokes
Here is what mine looks like. Am I missing somthing
12-31-2008, 03:04 PM
on
There is an adapter that that screws into. Let me see I might have a picture of one. It is called an NPT fitting.
EDIT:
This is an Autometer 3/8" NPT fitting.
12-31-2008, 03:05 PM
yes there is an adapter fitting that screws into water port and the piece you have pictured screws into,the bulb then seals in the adapter
12-31-2008, 03:26 PM
Master of Strokes
But the one on that wire screws into the water pump so why do need the other one?
12-31-2008, 03:28 PM
the other one is the other half of the seal
on
Because that one has a tapper to it that fits in the mounting nut and seals the connection. the mounting nut seals the port.
