Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Early Broncos (1966 - 1977) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 12-31-2008, 11:43 AM
Cheshire Cat's Avatar
Cheshire Cat Cheshire Cat is offline
Cheshire Cat is starting off with a positive reputation.
Talking Alternator up grade??
I'm looking to upgrading my charging system. I'd like to use a newer Alt that has a internal regulator with a higher amp output for lights, winch, stereo, ect...
Anyone know whats a good Alt to use and how to you bypass the old external regulator?
Thanks
Happy New Years!!!
__________________
1969 EB, 302, 3 speed on the floor, f150 springs up front, 2in lift leafs rear, font disc's, working on power steering and EFI. 1966 Mustang 302, c4. Both under construction..
  #2 (permalink)
Old 12-31-2008, 06:54 PM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE.
There are many different options for high output alternators. It depends on what you want and how much you want to spend.
There are int regulated GM alternators with outputs of up to 200 amp. And the Ford 3G swap is very popular.
I have a 3G upgraded to 150 amps with a one wire hook up on mine. The only problem I ran into was slipping belts. I had to modify a alt pulley for a smog pump application and run a second belt from the power steering. It works great this way, but I will eventually isolate the alternator from the power steering. I have mine wired directly to the pos side of the starter relay with a 4 ga wire. With this setup, the amp guage will only show battery discharge from cab accessories though. This keeps the high amperage (heat) from going through the light gauge dash wiring.
If you do a search in this forum for 3G alternator, you should find all you need to know for applications and how to connect it. The GM alternator will be similar to this. You will just need to find out what connections the alternator has.
Jason
__________________
"Giggity" Missing your Prius? Check under my tires.
'08 Dodge 2500 MegaCab 4wd, 6.7 Cummins, 6 spd auto, DPF & EGR fell off
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
  #3 (permalink)
Old 12-31-2008, 07:19 PM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
2004 Ford F-250
1975StroppeBaja has a good reputation on FTE. 1975StroppeBaja has a good reputation on FTE. 1975StroppeBaja has a good reputation on FTE.
Go to the classicbroncos.com forum and send RRRAAAYYY2 a pm about this. He is the starter and alternator GURU over there and can hook you up.
Not sure about his prices though....?
Here's the website of his company...
SVA Power Products
Good luck.
  #4 (permalink)
Old 01-02-2009, 06:34 PM
thanks for the info, I think the 3G is what i'm leaning to. I'll check out that web site and look up RRRAAAYYY2 over on cb.
__________________
  #5 (permalink)
Old 01-14-2009, 01:07 PM
Ok, I picked up a 3G alt monday from the local pick-n-pull.
Its from a 95 Tarus 3.0 v-6.
Looking to install it in the next few days. I was looking at this diagram.
ClassicBroncos.com Forums
I was wondering on the LG/R wire do i need to run the 510 ohms resistor/charge lamp or can i run it straight to a hot in run? If i need one where would i be able to pick one up?
thanks
__________________
  #6 (permalink)
Old 01-15-2009, 02:33 PM
mcdobson mcdobson is offline
mcdobson is starting off with a positive reputation.
If you don't have a light on the dash, just wire it direct. According to my research.
  #7 (permalink)
Old 01-15-2009, 06:25 PM
RCrawler's Avatar
The green/red wire in the alternator harness should be connected to the green/ red stripe wire at the Bronco regulator.
Jason
__________________
  #8 (permalink)
Old 01-19-2009, 05:40 PM
Just wanted to thak you guys for your info.
I stalled the 3G Alt this weekend and it went in with no problems.
Charging at a good 14.4v Everything seems to be working great.
Thanks again. One step closer to putting in my EFI.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
