Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero and 1961 - 1967 Econoline
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 12-31-2008, 08:31 AM
bobacus bobacus is offline
bobacus is starting off with a positive reputation.
1967 econoline van just purchased
new to forum just got a 1967 econoline heavy duty van ,,,, jacked to start work on it... E16AHA20155
body in good shape, engine currently partial back together 6 banger.
can anyone tell me based on the vin if it is a 240 engine?
  #2 (permalink)
Old 01-01-2009, 05:29 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Guru
NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation.
Welcome to FTE
E16 = 1967 Super Van
A = 240 1V I-6
H = Lorain OH Assembly Plant
A20155 = 1967
__________________
Bill / Retired Ford Parts Manager / Ford Historian / SoCal Chapter Member.
Part Number Research: Trucks: 1928/1996 / Cars: 1928/1989.
  #3 (permalink)
Old 01-01-2009, 06:45 PM
driggster driggster is offline
driggster is starting off with a positive reputation.
I just bought a 1967 Econoline Supervan. Just to make sure the reservoir under the driver's seat is for washer fluid? the vin is E16AHB57164. other info 090 M E160 289 C 07 038000 129 4000 51. Any help would be appreciated. I also have a 1965 F-250 I recently bought to carry my motorcycles and haul my 1968 Airstream Tradewind. It has the 352 V-8.
  #4 (permalink)
Old 01-02-2009, 10:45 AM
Ford Parts Guru
Quote:
Originally Posted by driggster View Post
I just bought a 1967 Econoline Supervan. Just to make sure the reservoir under the driver's seat is for washer fluid? the vin is E16AHB57164. other info 090 M E160 289 C 07 03800 129 4000 51. Any help would be appreciated. I also have a 1965 F-250 I recently bought to carry my motorcycles and haul my 1968 Airstream Tradewind. It has the 352 V-8.
Welcome to FTE
A = 240 1V I-6
B56164 = 1967
090 = 90" Wheelbase
M = Wimbledon White
E160 = 1967 E100 Extended Van / 3800 lbs. GVWR
289: 2 = Medium Blue Crush Vinyl & Medium Blue Match Stick Pattern Vinyl / 89 = Econoline Super Van
C = Ford Type 3.03 / 3 Speed Manual all Syncromesh Transmission
07 = Ford 9" WCR-S / 3.00-1 / Non Limited Slip / 3,050 lbs. Rear Axle Capacity
3800 lbs. Gross Vehicle Weight Rating
129 NET HP @ 4,000 RPM
51 = Denver CO Ford District Sales Zone Office, where the original selling dealer ordered the Econoline from.
The w/shield washer fluid reservoir is round, mounts into a bracket that uses two screws to mount it.
But...the parts catalog doesn't show its location.
__________________
  #5 (permalink)
Old 01-02-2009, 11:02 AM
Bill, thanks a lot for your help. I figured that's what that reservoir was for, but wanted to double check. There is nothing about it in my chilton's book. The van is definately rough, but drives fine. I need to reattach the hoses for the wiper fluid, put new mirrors on, get the signals and brake lights working, and get the weatherstriping for the windows I pulled in a junkyard. Quick question for you though, to start it the first time, I need to spray starting fluid into the carb because I can't get fuel into the carb to start, but once it starts, gas is no problem. I put a new fuel filter on, hoping for a cheap fix, but it still won't start up. Do you think it's a fuel pump, or something else? I filled up when I bought it and drove the 40 miles home and almost went through a half tank. Would this indicate a leak and tie into the other problem? Any help or advice would be appreciated. Thanks, Derek
  #6 (permalink)
Old 01-02-2009, 12:51 PM
Ford Parts Guru
Check the fuel pump, as original there was a fuel filter there, and this was its only location.
This filter rarely gets changed, because peeps don't know it's there, so they install an in-line fuel filter instead.
The pump's filter is inside a tomato juice sized can that screws on.
C4AZ9365B .. Cartridge Type Fuel Filter (Motorcraft FG1A)
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
