interchangeable - Ford Truck Enthusiasts Forums
interchangeable
Old 12-31-2008, 04:56 AM
stewart460's Avatar
stewart460 stewart460 is offline
stewart460 is starting off with a positive reputation.
interchangeable
I currently own an early 77 f250 and i have my eye on a 78 or 79 f250 for cheap the pick up has a broken 400 and the bed is rust out in the front my question is i want to take the bed off the 77 and change the motor what complacations am i going to run into with the bed? and what with the motor swap besides the obvious motor mounts and bigger radiator?
What exactly do you do with the motor mounts situation?
Old 12-31-2008, 06:43 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
2WD or 4WD?
Old 12-31-2008, 04:46 PM
stewart460's Avatar
both are 4wd
Old 12-31-2008, 06:50 PM
bmuhlbach's Avatar
bmuhlbach bmuhlbach is offline
bmuhlbach is gaining momentum as a positive member of FTE.bmuhlbach is gaining momentum as a positive member of FTE.
should both have 351 or 400 modifeds in them beds are the same only differents in 79 fuel filler and vents are different then77-78 in my dealings with them
Old 01-01-2009, 05:19 AM
stewart460's Avatar
my 77 someone before me has put in a 460 . so are the frames any different or can i swap bodies? i guess another option is to take out everything from the motor back for 4x4 reasons being the other pick up will have a married set up and my 77 missing parts . If i go with this choice things should all bolt up shouldn't except the transfer case cross member? should the 4x4 lever fit through the existing hole ?
Old 01-01-2009, 07:48 AM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
If your '77 is a High Boy the bed bolt holes won't line up. The High Boy frame isn't as wide in the rear as the '77.5-'79 Low Boy's. You would just have get the right flywheel or flex plate to put the 400 in. I would try to find another 460. The shift levers are in the same position in the floor.
Old 01-01-2009, 02:00 PM
stewart460's Avatar
cant i keep my 460 in my 77 and just take everything from the motor back in the 79 because the tranny is a c6 i believe the only problem is the transfer case cross member but is solved by drilling new holes into the frame ?
Old 01-01-2009, 04:33 PM
bmuhlbach's Avatar
the trans will bolt up 351-400modified 429-460 are same bolt pattern.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
