Putting an F 650 lower dash panel in the X
#31
The ARB lockers and compressor came with the switched like that. The other ones I got from here.....
http://www.carlingtech.com/pdf/vl_serswitlegends.pdf
Played with the sizing and printed them on clear, sticker pages.
#32
I got the paint from a Ford dealership parts department. I used standard primer from Home Depot. The Ford cans aren't cheap and you'll need two. Dealer cost is $10 per can and they usually retail them for $20, but in my opinion, worth every penny. It matches exactly. Everyone who sees it thinks it factory, which was my goal.
#33
Don't mind you asking at all - that's why we're all here....
#34
WOW- wish I saw this post before installing my air lift guages in my center console- but I like the looks of your set up alot!!- does that section of dash fit exactly into the 01 X dash area?
Can you tell me the ford part number and what you paid for it? I can always find gadgets to fill the space with!!!
#35
I would assume every Ford dealership would have the paint - it is a genuine Ford part.
Dash part #'s
1C4Z80044D70-CAC 2 hole option
1C4Z80044D70-AAB 1 hole option
And as "weekendwarriorfsw32" knows, there is a lot of work involved. Yes it does fit exactly but a lot of cutting and epoxy. I used the 1 hole option and cut the second hole myself.
Dash part #'s
#36
Great post,.....but I'm kind of confused? Nick the first pick you show at the start of your thread shows the cut out for the factory cup holders? Was that opening allready there, or did you have to cut that opening? was your part number considered the 1 hole, or the two? If you order the one hole part number, does that mean you get the long verticle opening, or the opening for the cup holder? That's where I'm still confused?
#37
Th!nk Parts Guy/FTE Parts Guy
#38
#40
I missed this thread somehow Nick. This mod looks awesome.
I tried to rep you but I still need to "spread it around" some more before I can.
Good job!
Stewart
#41
#42
If it helps I am only 16 and this stuff isnt to hard you just have to take your time and go slow
#45
Items used :
