Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Early Broncos (1966 - 1977) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 12-30-2008, 10:42 PM
v8xploder's Avatar
v8xploder v8xploder is offline
v8xploder is starting off with a positive reputation.
Aftermarket Radius arm mounting..
One of my future plans is to get a nice set of aftermarket radius arms for my 5.5 lifted 69. (I like the wildhorses versions) I notice that different company's sell adjustable frame mounts.
When I get to this point, should I just mount the arms in the factory locations or should I use aftermarket brackets.. How does a guy know where to mount the brackets? Hopefully this makes sense to someone out there! thanks!
__________________
Cody
69 Bronco, 351W, Edelbrock performer, Holley 670 T/A 35'S 5.5'' Wildhorses lift, Locker rear, F-100 power steering and a slight rear main leak
92 Bronco Eddie Bauer, 351w, 31x10.50 No rust!!!
  #2 (permalink)
Old 12-31-2008, 06:25 PM
RCrawler's Avatar
RCrawler RCrawler is offline
RCrawler is gaining momentum as a positive member of FTE.
It depends on what rear mounting the arms use. Many that I have seen get rid of the factory bushing mounts altogether and mount in the stock location, or farther back if they are extended.
I'm sure there would be detailed instructions for mounting with whatever arms you decide on.
Jason
__________________
"Giggity" Missing your Prius? Check under my tires.
'08 Dodge 2500 MegaCab 4wd, 6.7 Cummins, 6 spd auto, DPF & EGR fell off
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
