Never another piece of s**t ford again
#32
on
9 hours? Wow. I've gotten it down to under an hour. First time took 3. When I get in the zone I keep going till the job's finished without interrupt. I once decided I was going to detail my truck down to every nook and cranny... now that didn't turn out like I planned (8 hours) and I will never do that again only to have it look dirty again in 3 weeks!
#33
#34
#36
I can't find any coverage on injectors
I haven't seen anything to assure me that the injectors are covered under any warantee. Maybe under a new truck warantee, and the extende warentee pertains to the 05 and newer. My Certified Used warantee does not cover the injectors... I am hoping to hear something tomorrow, but I am not holding my breath.
#37
Ken is correct in saying that if the injector fails and isn't covered, all that fails because of it isn't covered either. Aftermarket warranties are the same. I had an engine rejected because the frost plug heater blew out and they overheated the engine. Frost plug wasn't covered so neither was the engine! Just understand that I do feel for you just be aware that dealers have thier hands tied at this point. As a tech in a Ford and Chrysler store, it's the same everywhere. I know the guys at the chevy dealer and they say the same. The economy and the situation the big three are in they don't want to budge. I've heard the japanese companies aren,t far behind the big three. We do try as much as we can for our customers. But honestly, we have a hard time and I know the customers are upset with us sometimes, but what are we to do?
#38
your opinon please as a tec
Now my dealer did want to quote me a price on a short black, but in my 04 I have them older style heads with the spark plug issues, so if I can I would rather move up to the newer style, somewhere in 06 they were redesigned.
In your opinion as a tec, which way would you go on this? New short block, long block if the 06 will work, or try to rebuild what I have. The dealer tells me no compression, piston burnt and valves gone, but they say they didn’t check the cylinder with the scope. I am wondering if the block is re-buildable and I am get a engine shop to do the rebuild at a lower cost to me.
#39
I would say you are pretty close, sounds like a good deal on the motor. You can check on how much a rebuild would be. I would like to see someone scope the engine to see how bad the bore is, if it's not too bad you may get by with a piston and valves. Either way is a rebuild just what you feel more comfortable with. Sorry about giving you bad news, I really do hate that and do feel for my customers.
#40
#41
Where does this info come from?
#42
#43
reman motor
#44
I got it in the rear
took my truck to the dealership :bad news: Valves and piston gone and no compression. They stated it was caused by a faulty injector. Now, since the injector is not covered under the “Ford Certified pre-owned Warrantee”, the damage to the piston, valves, and cylinder wall will NOT be covered. This is because the injector caused the problem and it is not covered.
This just blew me away… Back to the Bow Tie for me...
Reman engine $6361
rebuild with piston, if that is the only problem, and head work $5818
Reman gives me 12,000 or 12 months, and the same warrantee applies. Don't cover injectors.
If Ford keeps this crap up they won't be in business long.
bye bye Ford
#45
