How do I get the Rear View Mirror Glue off my windshield - Ford Truck Enthusiasts Forums
Old 12-30-2008, 08:06 PM
Ethan89 Ethan89 is offline
Ethan89 is starting off with a positive reputation.
A few years ago I bought the glue and fixed my rear view mirror that feel off. Now it has fallen off again. This time the plastic piece on the windshield broke but is still on the window along with the glue. What is the best way to get this off and clean it?
Charlie
Old 12-30-2008, 08:34 PM
Jermafenser Jermafenser is offline
Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.Jermafenser has a good reputation on FTE.
I used Goo-Gone when mine broke off. Great all-purpose adhesive/paint remover.
Old 12-30-2008, 08:55 PM
rainbowATF rainbowATF is offline
rainbowATF is starting off with a positive reputation.
The glue is basicly superglue. Acetone (real nail polish remover, not the eco stuff) should soften and remove it. A single edge razor blade will help. Don't get to physical by chipping away at it; you can chip your windshield ( how do I know?). Acetone also melts plastic, paint etc. So mask off, work careful and use drop cloths.
Old 12-30-2008, 10:33 PM
White EddieB White EddieB is offline
White EddieB is starting off with a positive reputation.
Quote:
Make sure the windshield is absolutely clean when applying the new glue, and warm too.
Old 12-30-2008, 10:49 PM
Gevans17 Gevans17 is offline
Gevans17 is gaining momentum as a positive member of FTE.
razor blade
Old 12-31-2008, 05:22 AM
jnewkirk77's Avatar
jnewkirk77 jnewkirk77 is offline
jnewkirk77 is starting off with a positive reputation.
I've always used an old rag soaked with acetone -- wring it out so it doesn't drip -- to soften the glue as was recommended, and then scraped the glue off with a razor blade. If you soften it up well, a dull razor blade will work. I would recommend a dull blade to avoid scratching the glass. Trust me on this!!!
Once you get all the glue off, you can use rubbing alcohol or ammonia to clean the glass prior to re-gluing the mirror mount. When you do this, don't mount the mirror itself for about 24 to 48 hours. You want that glue to set up really, really hard.
Old 12-31-2008, 06:39 PM
db916gt's Avatar
db916gt db916gt is offline
db916gt is starting off with a positive reputation.
Razor blade and Acetone... or the stuff that comes in the new glue kit... OOOOHHHH that is acetone.... But seriously, the razor blade helps get the chunks off of the glass and the stuff cleans it up and makes it ready for the next gluing.
One other option... Buy a new windshield.. LOL... just kidding.
Happy New Year
DB916GT
Old 12-31-2008, 07:09 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
use epoxy to keep it on.
put only the bracket on, let dry 10 minutes, put packing tape over it to hold it down tight, leave overnight, pull tape off carefully, put on mirror.
Old 12-31-2008, 10:30 PM
colemanw's Avatar
colemanw colemanw is offline
colemanw is gaining momentum as a positive member of FTE.colemanw is gaining momentum as a positive member of FTE.
razor blade is the quickest and cleanest
Old 01-01-2009, 12:40 PM
bullredguy bullredguy is offline
bullredguy is starting off with a positive reputation.
that's the problem with replacement plastic brackets they sit there in the sun all the time and get brittle be careful and warm it slowly i use a disposable type lighter and just dance the flame on it to bring the temp up nice and even use a pair of needle nose pliers and grasp the bracket and wiggle it slowly and you will notice the bracket will come right off dont use excessive force or you will be repacing the glass. as you have seen on newer modle trucks and all that they now black out the area where the mirror attaches to to the glass to prevent the uv light from burning the glue and your mirror falling off
94 Mirror cschannuth 1987 - 1996 F150 & Larger F-Series Trucks 0 09-20-2013 05:08 PM
94 F250 Rear View Mirror cschannuth 1999 to 2016 Super Duty 0 09-20-2013 05:04 PM
Sliding window latch Lubbockguy1979 1999 to 2016 Super Duty 1 08-02-2009 06:48 AM
Rear view mirror metal tab won't come out 6CylBill 1987 - 1996 F150 & Larger F-Series Trucks 22 06-30-2009 09:53 AM
Rear view mirror glue. nightowl_52 General NON-Automotive Conversation 10 07-14-2005 06:05 PM
Tags
adhesive, f150, falling, ford, glass, mirror, rear, truck, view, windahield, windsheild
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
