Ford 9" Third Members
The only differences you should run into is the different axles (28 vs. 31 spline) and the pinion yokes are not all the same. Neither of these things will keep the third member from fitting in the housing though.
Also some of the earlier rears had the fill plug in the housing and no plug in the third member. Still would fit but could end up with no way to fill/check.
https://www.ford-trucks.com/forums/2...xle-swaps.html
More info then you ever wanted to know;
Kevinstang's Ford Nine Inch Differential Page +
