Ford 9" axle width
Ford 9" axle width
The rear axle on my 71 F100 4x4 is about 4" narrower than the Dana 44 in the front. I put stock 79 Bronco rims on it and it doesnt look right because of the diffrent axle width.All the rims have the same backset, why did Ford build these rearends so much narrower than the front?
"bowties in the rearview mirror"
Ford 9" axle width
The reason the track widths differ from front to rear is for handling. If you look at the older Chevy's and Dodge's, you will notice the difference in axle width. The front is usually wider than the rear. As to what difference the width makes for handling, I do not have an answer, but I have been told by many people that is the reason. Another reason for the front being wider may be to allow for the front tires to turn. The distance from the rear tires to the springs would not allow much of a turning radius.
Ford 9" axle width
I just recently replaced the rear axel in my '72 F-100 4X4 as you did & had the same question. Mine was 4" shorter in the rear also. I replaced it with a Ford 9" 31 spline. I noticed its a lot better ride, feels more balanced. And as luck would have it the gears are the same. I got it out of a 74 F-150 4X4.
Mitchissippi
17
03-03-2016 07:07 PM
